Bronco II Ford Bronco II
I need Help Fuel Pump Does Not Run
Old Jul 26, 2005 | 11:12 AM
Sawfish's Avatar
Sawfish
This may be of no help, but it seems you are at the try anything stage. I had a Jeep that would start and run for a while, but would literally run out of gas with a full tank. Finally traced it to a stopped up filter inside the fuel tank. It seems the pump would suck up dirt/rust etc. which would stop up the filter. After the suction was released the particles would drift back down into the tank, until the next short trip. Failing that, you may need electronic brain (computer) surgery. Good luck.
Old Jul 26, 2005 | 08:38 PM
Ken00's Avatar
Ken00
What did you bypass to get it running?
Old Jul 26, 2005 | 09:24 PM
Monty06's Avatar
Monty06
not sure exactly me and my father rigged it somehow. father mostly did the trick
Old Jul 27, 2005 | 07:54 PM
Ken00's Avatar
Ken00
If you can find out maybe we can help you pin down the original cause.
