installing 2004 trans cooler into 99,
Old Jul 14, 2005 | 11:59 AM
fsheare's Avatar
fsheare
The 2004 trans cooler is 3 times the size of the 1999, would this be a good swap? The 04 has larger fittings, which should be less restriction. Anyone out there done this or have a professional opinion on this swap in an F350 diesel .. Thanks .
Old Jul 14, 2005 | 03:26 PM
Max1775's Avatar
Max1775
I haven't done it personally, but others have. The installation is supposed to be pretty easy. If you can get one cheaper than an aftermarket cooler, it'd probably be worth it. If not, I'd go with a big plate cooler from Hayden or Tru-cool.
Max
Old Jul 14, 2005 | 03:39 PM
touchofgrey's Avatar
touchofgrey
I guess you didn't like the answers on your identical post yesterday.......
Old Jul 14, 2005 | 03:51 PM
Max1775's Avatar
Max1775
He posted the same thing yesterday? That's a little odd... Maybe he doesn't know how to use the site...
MAX
Old Jul 14, 2005 | 04:03 PM
touchofgrey
MAX
Check it out on page two......
Old Jul 14, 2005 | 04:18 PM
Max1775's Avatar
Max1775
Hmmmmmmmmmm, maybe short term memory loss? Possibly Alzheimer's or even a minor concusion. I wonder if he has blurred vision, headaches, tttrembbbling hands, or dizziness. Might ought to see a physician about that problem...
Max
Old Jul 15, 2005 | 10:38 AM
fsheare's Avatar
fsheare
Placed same thing in many different forums, just got carried away!!! The Ford unit 2004 is a plate type cooler, 19" wide x 17" long. Should just about cool anything.
Old Jul 15, 2005 | 11:04 AM
touchofgrey
Yes, it is a good choice......and yes, it will bolt up.
wildstang
May 18, 2020 07:50 PM
wildstang
32
Aug 6, 2010 11:00 AM
82f3504x4
May 12, 2008 06:25 PM
fsheare
All Things Towing
Aug 30, 2005 03:01 PM
