Fuel pump/pressure
Old Jul 14, 2005 | 08:29 AM
Ron/PA's Avatar
Ron/PA
Fuel pump/pressure
I have a 1990 motor home built on a 350 chassis. 7.5 engine. It sat for 10 months and when I took it out, it starved for fuel. Thought it was the fuel filter, changed it roadside, and it started. Only made another 10 miles and it happened again.
When I broke the line at the filter, I couldn't get any pressure from the pump. Finally after much banging and priming I was able to get it running again and home. Still not running right, and I don't know what finally happened other than I banged on the tank, and topped it off with 3 gallons of gas.
Thanx
Ron
Old Jul 14, 2005 | 08:40 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 14, 2005 | 07:32 PM
Ford_Six's Avatar
Ford_Six
The pump is probably on it's way out. Banging on the tank might have freed it up a bit, but I wouldn't trust it for any length of time.
Old Jul 15, 2005 | 07:49 AM
Ron/PA's Avatar
Ron/PA
Thanx Jared, I guess you confirmed what I feared. LOL
I'll start draining the tank as soon as the rain quits.
Ron
Old Jul 16, 2005 | 11:11 PM
T18skyguy's Avatar
T18skyguy
Ron, this is just another alternative that some guys use to avoid pulling the tank. One thing you can do is pull up the carpet and measure carefully and use a hole saw directly over the pump and yank it out that way. Another thing some guys do is just put an aftermarket in-line fuel pump in the line near the fuel filter and run the electrical from the old pump to it. The inline filter will draw through the defective pump with no problem.
Old Jul 17, 2005 | 11:52 AM
LxMan1's Avatar
LxMan1
Most electric pumps don't suck real well. they prefer to push, so the restriction of the pump in the tank may cause problems.
