Dash Pad
Old Dec 19, 2002 | 11:04 AM
padd77's Avatar
padd77
Dash Pad
I am wondering how to remove the dash pad in my 77-f150. I have scored a perfect one in an old 76 that is sitting in a guys yard. But I don't know how to remove the one that I have or the one that I need. Thanks
Old Dec 19, 2002 | 11:07 AM
jalampi's Avatar
jalampi
Dash Pad
It is bolted from the bottom side.
1997 F350 PowerStroke,5 Speed, 4X4,36 Inch Buck Shot Mudders, Strait Piped, Chiped, Propane Injected, LUK Clutch, Reverse Shackle Kit
Old Dec 19, 2002 | 11:23 AM
beartracks's Avatar
beartracks
Dash Pad
It has studs that extend into the dash. You will have to remove the glove box, inst. panel and maybe the heater controls. Around ten nuts hold it on.
Old Dec 21, 2002 | 09:22 AM
skips69's Avatar
skips69
Dash Pad
There are (2) nuts on the outside corners that you will have to remember to look for - I remember these from my first dash pad pull, couldn't find them for awhile. Also, the one in the middle where the dash pad turns down - it hides as well. Keep these specifically in mind before you ruin it trying to jerk it out when you thought you had them all. A small pen light helps tremendously as well.
Good Luck, the first is the worst!
1979 Ford F150 4x4 Short Bed
1969 Mustang Sportsroof
2001 Ford Escape 4x4 (sort of)
Old Dec 21, 2002 | 09:38 AM
jor's Avatar
jor
Dash Pad
I have some photos that I took when I removed my dash which show the bolts and the process. Email me if you want them.
jor
Old Dec 21, 2002 | 01:30 PM
cjcathey2002's Avatar
cjcathey2002
Dash Pad
bbf150
17
Jul 28, 2014 10:38 AM
Ripcity
Sep 30, 2013 07:36 PM
bretts3504x4
Aug 28, 2006 05:21 PM
wiznewski
Nov 5, 2003 05:02 AM
amwxx
Jun 9, 2003 05:20 AM
