New Hedlight lenses?????
Old Jul 13, 2005 | 05:14 PM
Blkbstr's Avatar
Blkbstr
My headlight lenses are REALLY "yellowed" and old lookin. Does anyone have a good place to get stuff like that?
Old Jul 13, 2005 | 05:15 PM
ford390gashog's Avatar
ford390gashog
whats the year and model.
Old Jul 13, 2005 | 05:59 PM
94van's Avatar
94van
Check Here and see if yours are listed.
Old Jul 13, 2005 | 09:57 PM
DadVan's Avatar
DadVan
All,
Actually, this is similar to a question I've been meaning to ask as well... Has anybody tried the "clear lens" replacement headlights seen on eBay? At $90 a pair, I'm tempted to try them just to see if I can get some extra light on the road. I don't NEED 'em yet, just asking...
On the issue of "cataracts," as I call the yellowed headlamps... I've owned a lot of Fords with the %&*$# composite headlamps, and it's even worse for me because 95% of the time I choose to drive with the headlights. I usually just breakdown and buy a new set every three years and call it good. Using plastic polish is discussed in some length in several posts on the Aerostar forum, that works for a while, but nothing "fixes" the issue long-term. Replacement is the only/best option...
So..... With that said, I'm game for looking at cheaper solutions like these import lamps.
Feedback?
DadVan
Old Jul 17, 2005 | 01:45 AM
skier-24's Avatar
skier-24
If they are not too bad, chrome polish will clear them up. I have also used 1500 grit wet sanding and then follow that with 3M Plastic Polish and Cleaner. Takes a lot of elbow grease but cheaper than new headlights.
Old Jul 17, 2005 | 09:15 PM
Clubwagon's Avatar
Clubwagon
Originally Posted by DadVan
All,
I have replaced mine once already and the new ones are now also yellowed. I would like to know more about polishing them. Can you tell me anything about the process? What to use, etc...
Steve
'95 Clubwagon XLT
Old Jul 18, 2005 | 05:13 PM
maples01's Avatar
maples01
You get what you pay for I'm affraid, after helping someone locate affordable replacements, water gets in the replacement when it rains, also has yellowed a great deal.
Old Jul 19, 2005 | 07:00 PM
Blkbstr's Avatar
Blkbstr
Thanks for the idea! I'll try it.
Old Jul 19, 2005 | 09:05 PM
Eco?noline's Avatar
Eco?noline
The point is, the UV in sunlight affects the plastic lens, and this is going down deep in the structure of the plastic.
When you polish it frequently, you can save them for a few extra years.
If they're too yellow you're too late, it's too deep in the structure, you've to grind the yellow surface away and that affects the strenght off the lens.
Maybe, a good solution could be to paint them with a clear coating with an UV-filter or the use of a clear film with the filter.
I'm going to do some research, mine need replacement to, if it's not possible, then i'm lucky that i'm living in a country with not very much bright sunlight.
Rudi
Old Jul 27, 2005 | 10:24 PM
shoman89's Avatar
shoman89
I bought the $90 pair for my 94 e150 off ebay and they were not too bad. Better then expected and much better than the yellow old ones.
-JeffP
Old Jul 29, 2005 | 06:51 PM
DadVan's Avatar
DadVan
shoman89,
Did the light outa the "cheapies" go where you expected?
DadVan
Old Jul 29, 2005 | 08:55 PM
shoman89's Avatar
shoman89
Yes, they petty much looked just like the originals but clean and clear. I don't have any complaints except the way ford attaches the headlights to the van. It was a real PITA! I don't remember exactly which vendor on ebay I bought from, so I can't say for sure which ones I bought. I will see if I can figure it out and let you know.
JeffP
