recently the check engine light came on. code scanner gave po 1740 code
2 weeks later no a4wd,4lo,or 4 hi. could this all be related or 2 different causes?
99 expedition 4x4
4.6L
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
99 expedition 4x4
4.6L
P1740 Transmission system problems.
Sounds like it!!
I new it was a solenoid, but thought it the one that engages the 4 wheel. I believe you will have to go into the tranny for that, but don't count on it. Tranny's are my weak point, but all you have to do is call up a tranny shop, not Ammco or a major repair place. Call a local guy and he'll tell you what's involved over the phone. Get a quote while your at it so you know what to expect.
