Power Steering Q
Old Dec 25, 2002 | 02:47 AM
Racerdave's Avatar
Racerdave
Power Steering Q
I have power steering and a new Grant Steering wheel, after I bought the truck I drove her home and noticed the steering was very sencitive and had to be very carefull, I have driven a truck like mine with power steering befor and it was nothing like this, if i turn the wheel a little it starts that way and wont straighten its self out if I let go. The alignment is fine, I can point her straight and she stays straight. I was just wondering if the power steering was suposed to correct its self? Somone also told me that in some older trucks there is a spring in the steering that slowly moves the wheel back to the normal position?
Old Dec 25, 2002 | 03:56 AM
macguyver's Avatar
macguyver
Power Steering Q
Dave,
There's no spring that recenters the steering. Try jacking up the front end and setting it on some good jack stands. Then grab hold of the tire and see if you can turn it side to side with the engine off. The kingpins could be stuck/gummed up/in dire need of grease. The power assist will overcome the stickyness but normal driving might not. Also, if the steering box is set too tight it will do the same thing.
Just my $.02
Greg
'77 F-250 Camper Special 400ci driver
'76 F-250 Supercab 360ci current project
'71 Mach I 429CJ in storage
'79 F-150 for parts
huct on foniks wurkt fer me
Old Dec 25, 2002 | 04:14 PM
Racerdave's Avatar
Racerdave
Power Steering Q
[updated:LAST EDITED ON 25-Dec-02 AT 05:15 PM (EST)]So it should normaly recenter its self? How would I know if my Steering box is to tight?
Old Dec 25, 2002 | 04:41 PM
Torque1st's Avatar
Torque1st
Posting Legend
Power Steering Q
The "re-centering" is a function of the caster angle. With low or no caster the vehicle will not straighten out.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Dec 25, 2002 | 07:25 PM
fordblue_ca's Avatar
fordblue_ca
Power Steering Q
You might just have to loosen your power steering a bit, My steering is very loose and if I had tightend it up too much It was pretty sensitve and would not return after cornering. Very easy to adjust, so I would try that first.
just my opinion,
Joe
Old Dec 25, 2002 | 07:49 PM
Racerdave's Avatar
Racerdave
Power Steering Q
>just my opinion,
>Joe
"And how would I do that? Is it by the pump or what?"
Old Dec 25, 2002 | 11:10 PM
fordinlinesix's Avatar
fordinlinesix
Power Steering Q
robs_seven
17
Oct 22, 2011 07:49 PM
nmidthune
Mar 1, 2007 08:44 AM
plitz.....
19
Apr 25, 2004 08:17 PM
Racerdave
May 23, 2003 02:03 AM
tim71ford
17
Aug 8, 2002 08:55 PM
