Sponsored by: Real Truck
winch size
Old Jul 12, 2005 | 06:58 PM
unluckylow's Avatar
unluckylow
winch size
Quick question. I am able to get a 8000 lb winch for $299.Is this a good price and do you think it is big enough to pull me out if I get into a situation.I have a 2000 F250 PSD with a 4'' lift with 35'' tires. I know the bigger the winch the better.....just curious as to what you guys go with. Thanks
Old Jul 12, 2005 | 07:03 PM
high ho silver's Avatar
high ho silver
With the stock weight of your truck, you could use it as the ancor and pull others out of sticky situations with an 8K winch but you probably will not be happy with it for pulling yourself out. Multiply weight of truck and suction created by mud and an 8K will have a tough time to say the least.
Old Jul 12, 2005 | 07:06 PM
ford390gashog's Avatar
ford390gashog
a 8k winch is to small. the 8k may just be a rating for rolling mass and not a stuck truck i use a 15k winch on my 75 and it gets the job done but i am going to a bigger one sometime.
Old Jul 12, 2005 | 07:12 PM
unluckylow's Avatar
unluckylow
I didnt even know they made bigger than 15 for automovie purposees (WOW). How much is a good price for a 12 to 15 new or used. I hate going out with friends cause none of their trucks can pull me out if I get in some holes Ive been in before.
Old Jul 12, 2005 | 07:13 PM
04superduty's Avatar
04superduty
the rule is 1.5 times the weight of your truck and your truck weighs roughly 7000 lbs, give or take.
Old Jul 12, 2005 | 09:54 PM
99f350sd's Avatar
99f350sd
I would geta 10k. I have a 9k warn it works good. Get a name brand some are too slow.
Old Jul 12, 2005 | 10:05 PM
hc130flyboy's Avatar
hc130flyboy
I use a Ramsey RE8000 Worm Gear winch and it gets me out of anything! had to add an optima battery but it works great!
Pics in gallery
Old Jul 12, 2005 | 11:35 PM
MAXEY's Avatar
MAXEY
dont mean to steal a thread but did you get that with the winch(the mounting bracket for the winch) that looks pretty nice
Old Jul 14, 2005 | 07:48 PM
hc130flyboy
I built it out of 3/8" steel and boxed channels and welded up a carrier, sticks out more than the Warn kit but my winch also has a spur gear thus a "worm gear"
Old Jul 14, 2005 | 08:55 PM
ford390gashog
i adapted a electric winch of a flat bed tow truck.
Old Jul 14, 2005 | 10:43 PM
thewizard's Avatar
thewizard
Thumbs up The right size...
Life-long Philosophy ...
Figure out what the biggest size you could ever possibly need is... and get the next size up.
This works for winches, wrenches (but not wenches), tools, trucks and most all guy things.
Old Jul 15, 2005 | 01:27 AM
Munkey's Avatar
Munkey
Don't they have a 16.5k winch now??
What about buying that winch, along with a ****** block (or two), a tree saver strap, and some lengths of chain, to use it all for double-line winching? Wouldn't that theoretically turn that 8K into a 16K (very...slow) winch?
Check out this page for info on double-line winching:
http://www.innovation-engineering.co.uk/theory.htm
Old Jul 15, 2005 | 10:00 AM
iskybantilus's Avatar
iskybantilus
a ****** block doubles the line strength, and theoretically doubles the pulling power, but as you are stating it will have the speed.
I guess it depends on how much you go out and think you might end up using it. if your going to use it a whole lot, it is worth having the bigger, but if its that once a year type thing (and only if you get stuck) and depending on how conservative of a driver you are. so long as you have enough cable on there to double it up, you have that option to pull most anything you should need to.
Then again, if your like most of us ... you'll buy the biggest one anyhow.
