Timing issues
Old Jul 12, 2005 | 12:12 PM
66beater's Avatar
66beater
Timing issues
I set the timing on my 352 last night after having run it a few days with just a static timing (Set it by ear, the light was still packed). It had been running fine, but with the vacume advance unplugged, it showed to be running 25' advance at idle. I reset it to 10' as described by the FAQ here on the board, and it seems to now run poorly. It has no power when I hit the gass, and at around 3500 ropm, it peaks out and won't go further. I can't take off from the light in second anymore, and will try to stall in first. The motor is stock except for a rebuild 10 years ago.
What could be wrong with my truck, or what should I be setting my timing at?
Old Jul 12, 2005 | 12:33 PM
bshackelford711's Avatar
bshackelford711
sounds like to me that is to low. I think that it might need some more.
Old Jul 12, 2005 | 01:06 PM
Bear 45/70's Avatar
Bear 45/70
What do you have for a dist. and what is the advance curve? What else does then engine have for cam, compression, carb, etc? What is your total machanical advance? 25 degrees is way to much initial on any engine other than race only.
Old Jul 12, 2005 | 01:13 PM
Ronin4x4's Avatar
Ronin4x4
But if it really was to much it would be pinging. So why worry if it sounds good by ear, but runs crappy when you time it by light. If your ear and plugs say its fine it is. put it back where it was.
Old Jul 12, 2005 | 01:46 PM
Bear 45/70's Avatar
Bear 45/70
This is the kind of thinking that burns up engines. The are alot of reasons why he either doesn't hear the pinging or doesn't know what the sound means. For 25 degrees to be acceptable for initial, you would need a dist. that has a 7 1/2 degree advance cure(15 at the crank) and you would still need to run premium gas.
Old Jul 12, 2005 | 01:52 PM
66beater's Avatar
66beater
In answer to Bear45/70, Its all whatever came from ford in 66. bonestock original except for a 60 bote at rebuild. dist is the original, but In great shape. The vacume advance was replaced when I rebuilt the autolite carb a few weeks ago.
Since my last post I went and re-timed it to 20'. Major improvement.
So what is the best way to find the optimum timing for this thing?
Old Jul 12, 2005 | 02:15 PM
hiball3985's Avatar
hiball3985
be sure the engine is at a slow idle speed 500-550 rpm when setting the initial timing, anything higher and the mechanical advance comes on and will give you a false reading, 10 degrees at idle should be enough,
Old Jul 12, 2005 | 05:49 PM
Bear 45/70's Avatar
Bear 45/70
Those dist.'s usually had 13 degrees in the dist., 26 degrees at the crank. Some however had 10 in the dist. and 20 at the crank (this one was usually a high performance dist). The mechanical advance should be no more than 36 total. So 10 with a 26 degree dist. and as much as 16 with a HiPo dist. The vacuum advance will be on top of the 36 total. My '69 428CJ had a 13 degrees dist. and ran 10 degrees initial, at least until I dual pointed it so I could play some games with the dwell/ timing. You 20 is to much.
Old Jul 12, 2005 | 07:07 PM
mmuenchow's Avatar
mmuenchow
do you have the vac line to the dist attached to ported vacume?
do not use manifold vacume.
Disconect the vacume line and attach your timing light and check your mechanical advance. attach your vacune line and check total anvance.
set your timeing to 8deg before tdc and make sure that your carb gives that fe a big shot of fuel when you start to accelerate.
My 352 did the same thing. bad advance with a slow hole shot of fuel.
Old Jul 12, 2005 | 07:25 PM
66beater's Avatar
66beater
been timing at 500 rpm, Vacume disconected and plugged while the light was hooked up. at 6-8 degrees it might start on the third try, won't run without someone working the throttle. at 10 degrees it will run, but badly. at 20, it runs fine. It still runs fine at 30, better actualy. Idles smoothest about 26, and I haven't tried everything yet, but seems to run smoothest at highway speedss when I set the idle between 20 and 30.
Old Jul 12, 2005 | 07:34 PM
hiball3985's Avatar
hiball3985
something isn't right!!!! try using a dowel in #1, turning the engine by hand till you find TDC, see if your timing mark on the damper is at 0 or close, sometimes they slip, at the same time pull your dist cap off and see where the rotor is pointing in relationship to the #1 plug wire terminal
Old Jul 13, 2005 | 12:15 AM
Bear 45/70's Avatar
Bear 45/70
Very good idea. Should always do this on a rebuild before you totally bolt the damper on. Then you know the motor is at TDC and the degree marks on the damper are right.
Old Jul 13, 2005 | 07:30 AM
xfordman's Avatar
xfordman
My 390 was rebuilt completely stock and after 20K miles I had the timing chain cover off. The slop in that chain was unbelieveable. it was a stock type chain, not the double roller. I think this would retard timing. If this motor was rebuilt 10 years ago could this be a factor also? That said, checking to see if that the outer ring on the damper has slipped is a good idea.
Old Jul 13, 2005 | 11:01 AM
Bear 45/70's Avatar
Bear 45/70
Normally a stretched chain will cause the timing to wander, otherwise while running to move around. If the chain was loose enough it could jump and change the timing but the cam changes timing also and you cant rest it. Very shortly after the chain got that loose it will jump enough so engine won't run no matter what you do.
Old Jul 13, 2005 | 11:05 AM
hiball3985's Avatar
hiball3985
I agree with bear, it could have jumped 1 tooth and will still run if you change the timing, I just went thru that with my kids Dodge 360 motor
bigdan1979f-250
Oct 18, 2012 11:48 AM
johnson2007
May 8, 2011 07:51 AM
pidaster
18
Nov 15, 2009 12:21 PM
andrewasl
May 25, 2009 12:21 AM
bhardy501
May 12, 2007 07:33 PM
