starter solenoid?
Old Dec 26, 2002 | 07:21 PM
big_red_79's Avatar
big_red_79
starter solenoid?
i was working on my truck the other night and just put an edlebrock 750 on it, and i was leaning over into the engine compartment, and my mom was cranking over the motor, she hadnt been cranking for too long and i looked over and seen my solinoid was steaming cause it was prety cold out side, and the batery side was hot, i got a burn from it, what is causing this, can i just change the solenoid or is there something deeper in the electrical system?
any help is apreciated, oh yeah, its a 79 f-150 4x4 with elecrical parts from a 77, that shouldnt make a lot of difference should it?
thanks
NATE
Old Dec 26, 2002 | 07:40 PM
Torque1st's Avatar
Torque1st
Posting Legend
starter solenoid?
There is a poor connection there. The resistance produces heat when current flows thru it. The connection surfaces may just be oxidized or the cable end itself could be bad.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Dec 26, 2002 | 08:07 PM
V10KLZZ71S's Avatar
V10KLZZ71S
starter solenoid?
possibly could it be the starter drawing an excessive amount of amps?
Old Dec 27, 2002 | 04:28 PM
rustynuts's Avatar
rustynuts
starter solenoid?
could be a bad starter drawing to much current. i dont think the solenoid is bad. its basically just an on off switch. i remeber when my positive cable shorted to the block on my pontiac it got so hot instantly that it melted almost all the insulation. i hurried and disconnected it and the cable and post were hot for a half hour later.
Old Dec 27, 2002 | 05:37 PM
big_red_79's Avatar
big_red_79
starter solenoid?
well, the starter is brand new, it has only been used in this vehicle, and the solenoid is fairly new also, i'll try making a better connection
thanks
NATE
Old Dec 27, 2002 | 06:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
starter solenoid?
This was the clue:
>" i looked over and seen my solinoid was steaming cause it was prety cold out side, and the batery side was hot,"
-bad connection or cable.
The cable end can go bad from oxidation and corrosion internally between the wire and the crimped "cover" terminal. I have never liked those connections.
Old Dec 27, 2002 | 08:35 PM
Mil1ion's Avatar
Mil1ion
starter solenoid?
Ryan Weaver
Jan 4, 2015 04:30 PM
79silverstreak
Electrical Systems/Wiring
Feb 6, 2013 07:51 PM
outsource77
Nov 28, 2010 01:50 PM
76F250HighBoy
Nov 1, 2005 04:14 PM
BROCO
Feb 5, 2004 08:15 AM
