solenoid buzzing!!!
Old Nov 27, 2010 | 08:09 PM
outsource77's Avatar
outsource77
Question solenoid buzzing!!!
Hello,
Got in my truck, tried to turn it over, got a buzzing. Figured out the buzzing was coming from the solenoid on the passenger side. Got rid of the old one, replaced with a new one. Solenoid is still buzzing and the truck won't start! Are there any other causes for a buzzing solenoid other than it just being bad?? Any and all advice is appreciated! Thanks
Old Nov 27, 2010 | 08:12 PM
bigdaddys76's Avatar
bigdaddys76
dirty cable connections maybe
Old Nov 27, 2010 | 08:14 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Classic symptom of either a dead battery or as bigdaddys76 said a bad cable connection.
Check your battery and clean and tighten all the cable connections.
Old Nov 27, 2010 | 09:11 PM
JimsRebel's Avatar
JimsRebel
This can also be caused by a bad starter... which is drawing way to many amps, which will act like a dead short to the battery.
Old Nov 27, 2010 | 11:07 PM
seventysevenF150's Avatar
seventysevenF150
First things first, check the battery!
Old Nov 28, 2010 | 01:50 PM
outsource77
OK, cleaned the connection for solenoid and the battery. the battery tested at 12.6 so, I am thinking the problem is with the starter. Thank for the info evrybody.
RED DYE
Mar 28, 2017 08:19 PM
Raptor10
Sep 7, 2016 03:39 AM
izmepeggy
27
Oct 28, 2015 05:05 PM
Aki_A
Mar 22, 2011 05:33 AM
CPUNeck
May 13, 2010 09:16 PM
