79 cranking issues
Old Feb 5, 2013 | 09:21 PM
79silverstreak's Avatar
79silverstreak
79 cranking issues
Hey yall,
I've just gotten finished building a 400 for my 79 f250. On attempt to start it, I had no power to the coil, fixed that, blown fuse. Only now I cannot get the starter to engage via ignition switch. Solenoid does not click, I can engage starter by arcing either sides of the solenoid/ bypassing, so starter is fine. What am I missing?
Thanks, James
Old Feb 5, 2013 | 09:23 PM
m300diesel's Avatar
m300diesel
Are you saying you bypassed the solenoid and the starter engaged? If that were the case I would say you have a bad starter solenoid. hmm. Blown fuse sounds like a issue I would look into also. Perhaps a short in the wiring that feeds to one of your ignition coils.
Old Feb 5, 2013 | 09:27 PM
79silverstreak
Oh, probably should mention a pack of wires, I believe three, could be four, has come loose from the transmission somewhere, No reverse lights on account of this. Could theses wires go to a gear/ neutral position sensor? Where do I need to hook these wires back up on the case?
Old Feb 5, 2013 | 09:28 PM
79silverstreak
300 diesel,
Yes I am, in-order to start it.
Old Feb 5, 2013 | 09:39 PM
m300diesel's Avatar
m300diesel
If it starts after jumping your starter solenoid than the solenoid is shot. which happens. Could you possibly take a picture of these hanging wires and do you by any chance own a chilton or hanes manual with a electrical diagram or your vehicle?
Old Feb 5, 2013 | 09:46 PM
79silverstreak
After reading the post a couple down from mine, I'm fairly confident that theses loose wires must hook up to the neutral safety switch. The solenoid was brand new less than a year ago, it will key up the starter if you switch the little wires on it. I wish I cound take a picture, but do not own a camra, all the wires are hed together on a oddly shaped black plastic plug type deal, sort looks not whole.
Thanks for the help.
Old Feb 5, 2013 | 09:59 PM
m300diesel's Avatar
m300diesel
Well bad wiring can most certainly cause issues like you are describing. Sometimes parts that were bought new can go bad fast due to manufacturing problems or defects. I have bought plenty of parts that were bad over the years. Does the vehicle start every time you jump the solenoid?
If you feel certain that the wires you have noticed look suspicious then I would definitely direct my attention away from the starter solenoid I suggested and back to those wires. Does anything look broken, taped, etc (by this I mean something that the original manufacturer wouldn't have done). Do you have a voltmeter? I own one I got at Napa for less than twenty dollars and has helped me out of many jams. Fluke brand is the best though.
Old Feb 6, 2013 | 05:24 PM
Franklin2's Avatar
Franklin2
Go down on the side of the tranny, and see if you have two red/blue wires down there. If you find these, jump them together and see what happens. If you will notice, this same color wire is what goes to the solenoid small connection. These are the neutral safety wires.
Old Feb 6, 2013 | 07:51 PM
79silverstreak
Four wires, two red/blue, and a white and a black, tired different combinations, red/blue to read/blue, ignition switch worked like it should. Thanks yall.
triplecreek
15
Aug 4, 2014 01:57 PM
cfassett87
Jun 25, 2012 08:49 AM
78BigBlock09
Mar 30, 2010 02:48 PM
wporter4671
May 25, 2009 09:42 PM
rhrmusic
Apr 30, 2006 12:02 PM
