power steering pump noise?
Old Oct 2, 2002 | 10:27 AM
kelsey's Avatar
kelsey
i replaced my power steering pump on my 76 f250 and it keeps on whining at me. everyone i have talked to says it will go away after driving it for a while. it has been about a week and it is still making the whining noise. at first i thought it was the pump so i returned it and installed the new one. still had the same noise, so i bled the system and started to drive it around town. is this something i should be worried about? plenty of fluid and no leaks.
thanks
joel
76 f250
390 c-6
power assist
4x4
Old Oct 2, 2002 | 11:55 AM
beartracks's Avatar
beartracks
If it's bled and full and fluid I'm afraid you'll have to live with it. It may go away after a considerable abount of time. I've have pumps that were dead quiet and one that would drive you nuts. It must have to do with re reman process.
Old Oct 3, 2002 | 09:39 PM
Ford79's Avatar
Ford79
I thought a whining PS pump is what makes it a Ford :P
Old Oct 3, 2002 | 10:08 PM
jbulson's Avatar
jbulson
my reman pump said to use atf for fluid on the dipstick...Why is this?
Old Oct 3, 2002 | 11:20 PM
Mil1ion's Avatar
Mil1ion
The PLASTIC pumps Use F-type fluid.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Oct 4, 2002 | 03:55 AM
Torque1st's Avatar
Torque1st
Posting Legend
If the system has been cycled and the air bled out, then the noise comes from fluid bypassing from the high pressure side back to the low pressure side thru scratches and scoring in the valve plate and/or pressure plate. If it is noisy get your money back and buy another brand.
The reman/rebuilt pumps seem to be just cleaned and re-sealed at best. The quality of replacement pumps out there is absolutely abysmal. I needed a replacement for an Isuzu pump and bought a Cardone/A-1 pump, and returned it, and returned it, -got my money back and bought another brand (Atsco) which is still more noisy than the original pump but much better than the horribly mangled ones from C/A1. Some of the C/A1 pumps looked as if they had been run over by a Tank on concrete then painted and boxed, the ones I actually installed sounded worse. I lost my perfectly good silent OEM pump when I dropped it on concrete accidently:-) I would have been better off putting a new bearing and seals in my pump. To reman a pump properly may take a number of new components and the valve plates must be surfaced with some special processes to give them the proper finish and hardness. I suppose you could always take your pump to a hydraulic pump shop and leave it for a week or two...
Any time you replace a steering pump or component put a filter (Wix #58964 ~$17) in the return line. Rotate the steering wheel and push out all of the old fluid and replace it with fresh clean fluid. You may still have debris in the steering components but you will be better off.
Old Dec 27, 2002 | 08:55 AM
sethro's Avatar
sethro
this might be alittle late, but i noticed this with my 78 F250, i replaced the pump, etc. I finally replaced the belt and the noise went away. The belt was to wide, so it wasn't fitting into the pulley all the way.
i dont know if you tried a new belt, but it is worth a shot.
Old Dec 27, 2002 | 09:13 PM
fordmaniac21's Avatar
fordmaniac21
i aslo thought that all ford power steering pumps were noisy lmao. at leats they have been on all 3 of the ford trucks i have owned and all my freinds have had. i thinks its a ford trademark to have a noisy pump.
'75 F-100 4x4, 4" lift
35x15.5x15 super swamper TSL/SX
mini-spooled 9" rear end
390 w/ cam,headers,
and 4 barrell edelbrock
TRIED TRUE and FORD BLUE
Old Dec 27, 2002 | 10:53 PM
Torque1st's Avatar
Torque1st
Posting Legend
The pumps aren't silent, but a good pump shouldn't be heard over the fan and other engine noise.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Dec 27, 2002 | 10:57 PM
SHADE TREE's Avatar
SHADE TREE
sailorman3
Nov 5, 2016 08:22 AM
kpchambers
2009 - 2014 F150
Aug 23, 2016 11:52 AM
ATE88
Sep 15, 2015 10:53 AM
Halloran1
20
Mar 22, 2012 09:24 PM
5.4L to Freedom
Dec 16, 2010 05:51 PM
