Fix for Power Steering Whining?
Old Jan 30, 2012 | 08:04 PM
Halloran1's Avatar
Halloran1
I know that Ford has had problems for power steering whining for a while, and I'm just lookin to see if there's a fix. I got a '92 F250 with the 460 and C6 transmission. I asked the parts guy at Napa about it, and he said that because Ford used a plastic fluid container, it makes the whining noise. And that replacing it with an aftermarket metal container would stop the whining. I don't really think that's the case.... it seems to simple. I was thinking more along the lines of a new pump? It really only whines when I turn the steering wheel, and for a good 10 seconds after I straiten out. Truck runs fine, it just bugs me. I only got 71,000 miles on it too, so it can't be that worn out?
Anything helps. Thanks.
Old Jan 30, 2012 | 09:15 PM
IDIDieselJohn's Avatar
IDIDieselJohn
The guy has it semi right.
You have the replace the stock Ford C2 whiny pump with a GM style Saginaw Pump. Those have metal tanks.
All Ford E-series vans have Saginaw pumps.
Find a 92-97 E-series van with a 460, and get the mounting bracket and pump out of it, and swap it in your truck.
Old Jan 31, 2012 | 04:43 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
^^^^ This.
So many threads....
Why couldn't Ford have done it right in the first place?
Old Jan 31, 2012 | 07:04 AM
serious_lee's Avatar
serious_lee
Mine whined really bad until I read about using ATF Type-F in there. The last guy had been using the clear stuff and it sounded horrible. Flushed and filled and it's quiet enough for me.
Old Jan 31, 2012 | 07:16 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Always use Ford ATF.
Some say to add half a tube of limited slip friction modifier will make the noise go away.
Mine is seizing up.
Need to find a cheap van pump and bracket.
Old Jan 31, 2012 | 07:25 AM
Firefighter 1406's Avatar
Firefighter 1406
Either that or try and put full syn ATF in it. My Superduty was whining and flush with Mobil 1. Quieted it down a lot.
Old Jan 31, 2012 | 08:37 AM
slampig5spd's Avatar
slampig5spd
my was horrible while i was using regular cheap atf. not only would it whine but i also had a problem where id loose my caps. one day i decided to use some left over mercon and it stoped havent had either issue since
Old Jan 31, 2012 | 09:23 AM
Halloran1's Avatar
Halloran1
Thanks guys, I'll try all of those. I appreciate it.
Old Jan 31, 2012 | 05:08 PM
jedijeb's Avatar
jedijeb
Someone today gave me a tip that seems to work for this problem. Seems most of the whine comes from the fluid becoming aerated as it gets old. Simply changing the fluid makes a lot of the whine go away. Probably why the synthetic fluid makes less whine because it may hold up better and not get frothy.
Old Jan 31, 2012 | 06:08 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Flushing never made mine quiet.
Old Feb 1, 2012 | 01:59 PM
BigJT's Avatar
BigJT
Lucas makes a product that works really well on power steering systems. You can buy it at Napa
Old Feb 1, 2012 | 02:20 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Is this Lucas additive meant for ATF, or power steering fluid?
Old Feb 5, 2012 | 02:49 PM
yardbird's Avatar
yardbird
Put this in the pump. If it doesn't stop the noise, it can't be stopped. I've used it for years in many vehicles, with almost instant results. One Aerostat van had the pump full of water, and could be heard for about half a mile. After I flushed out the pink wipped cream, and installed new fluid, it was almost as bad as before. I put in Lubeguard, and within 10 minutes I couldn't hear the pump. Six years later it is still quite.
NAPA also sells this under their own brand, but in the same bottle.
Old Feb 5, 2012 | 05:47 PM
Thumper19's Avatar
Thumper19
on the saginaw pumps, use GM's power steering fluid. Its tested and rated to 10* and for 100,000miles.
Old Feb 22, 2012 | 10:43 PM
whiteboyslo's Avatar
whiteboyslo
So, Type F or Mercon III/V/Eleventy billion (or whatever number they're up to now)?
Mike
