Sponsored by: Real Truck
Air Brakes?
Old Jul 11, 2005 | 01:10 PM
Ducster1's Avatar
Ducster1
Air Brakes?
2005 F250 Powerstroke CC LB 4x4
Yesterday, I had to press real hard on the brakes. As I held the brakes down, I noticed air hissing sound coming from the brake pedal. I tried a couple of time on pressing hard on the brakes and it continued to hiss. The brakes do work, but was wondering if this is normal.
Old Jul 11, 2005 | 06:50 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Its the ABS working, its not air its fluid by basing
Denny
Old Jul 11, 2005 | 07:05 PM
captchas's Avatar
captchas
Guest
mechanics inout only
i'm not super up on the psd system . but to me it's something that needs to be checked . it may be the brake booster leaking as you stated i had to push real hard to stop. a hiss when pushing down and hard pedal is most of the time a booster problem.
please play safe and have it checked out.
Old Jul 11, 2005 | 07:27 PM
soupy264's Avatar
soupy264
power brakes use vacuum to assist the application.it sounds to me like you need a new brake booster, the larger part that your brake master cyl. bolts to. Since vacuum is really air pressure in reverse, it makes very similar sounds when leaking. good luck Phil
Old Jul 11, 2005 | 08:06 PM
rvpuller's Avatar
rvpuller
Just go out to your truck it doesn't even have to be running and jam the pedal down and what do you here. Its sound like air brakes.
Denny
Old Jul 11, 2005 | 08:38 PM
chimpter's Avatar
chimpter
It's a diesel so there is no vacuum. Your power brake booster is known as a hydrobooster which runs off the power steering fluid.
Old Jul 11, 2005 | 09:17 PM
soupy264's Avatar
soupy264
it's a diesel,so there is no vacuum is right. but that is why Ford, at least up to my old '90 has a vacuum pump below the alt, to generate vacuum. don't know if Ford has gone over to the Chevy way of using hyd. booster now or not Phil
Old Jul 12, 2005 | 06:05 PM
chimpter's Avatar
chimpter
The powerstrokes use a hydrobooster for the power brakes. The vacuum pump runs other accesories such as the ventilation system and automatic hubs.
