V-10 Let Me Down!
But nobody seems to be able to "stear" me in any direction. I'm not gonna just start throwing money at it.
Exhaust mod this . . .
Super Diablo Chip that . . .
Bigger throttle body over here . . .
Throw me a bone you posting magnates. What is your best opinion on what might be wrong?
Open up the exhaust?
Will removing the cat screw up the computer?
I want it to do what it should be doing. Right now I feel like I'm driving a "Rolls Kinardly"
[I]Rolls down one hill . . . Kinardly get up the next!
I would suggest you let a good tech (hard to find) hook it up for diagnostics and do a drivability test while under load - preferrably with your Trailer. Maybe he can see something going on that just won't throw a code.
Now, I hate to throw a wrench in the kitty but I've driven a V-10 that is owned by my bro in law, it's a dog, I mean a 3.8 Taurus engine in a F-350 dually could whoop it. But I believe the Y-pipe is congesticated, and have told my BIL the same. Except he doesn't care, as he drives the 'hotrod V-10'. So his guys drive this one and the other 4 or 5 V-10 F-series he owns. There was a fairly big discrepancy among some of the early V-10's in power. Fred is a smart dude, and he's been a giant help to many of us. I'd throw my cards in with him and try a couple of his suggestions. Couldn't hurt ? Ken
Did you say 25% grade earlier, holy cow thats some serious road. As a civil engineer I have to question it as there aren't many roads that are that steep for 2 miles. I gotta know where you're living as I've only been on maybe 2 roads that have broke 20% grades. I realize the mountains possess a few of these and I'm not exactly living in the mountain here in ND, lol. Don't take this the wrong way but thats some serious grade.
I would not spend money on any aftermarket power makers at this point. You need to unleash the stock power first. If it were mine I would:
1) Change the fuel filter.
2) Change the cat if you are reasonably sure it is plugging. I've had this happen to one vehicle, and once it started plugging it got progressively worse in a hurry. Do you feel you have lost any power or acceleration recently even when not towing? Hopefully others will chime in with their experience on clogged cats.
3) Swap your R&P to 4.30's. If your motor is performing properly, this will be your best bang for the buck IMHO. For about $1K you will get ten times the performance increase a $400 tuner will get you.
Good luck, and ya gotta let that V-10 rev baby, it does take a while to get used to it, but it's a revvin son of a beyatch. After a while you'll start jones'in for it, it's sweet, sweet music.
As far as a diagnostics or good "tech" . . . I'm in Cheyenne, WY, not a lot to choose from. I called evary big shop in town, including the Ford dealer, and all of them seemed to want to know "Any warning lights come on?". [/I][/B]Just hook it up and shut up!
Frustrationg. Going out again this weekend with the same camper/ATV load combo. I'll see what happens.
Live2hunt
Sorry to set your hair on fire and add to your frustration. You are right you have a problem. First, the old skool V10 is a very capable motor but in some configurations is already limited. I still don't have a great idea what your truck is weight wise.
So assuming a full boat crew cab 4x4 long bed with 3.73:1 gears and an early design E4OD/4R100 trans trying to haul 10,000lbs up and down the modest hills of Wyoming and a driver decidedly unhappy with the performance asking questions.
Yes sir there are some simple things you can do to gain some power.
Get a good set of radial designed "E" series tires no bigger than 30.6 inches tall (265s) but preferably done in 225-235 range. Smaller diameter tires is a cheap way to change effective gear ratio.
Get a competent exhaust shop to hack out the factory "Y" pipe, inspect the CAT for plugging (very rare) and fab in a decent 2 1/2" two to one collector to the cat. There is not much HP to be gained behind the cat unless you want to do a true dual exhaust system.
Since you don't say empty and normal cruise is a problem. Then lets assume you just need more ponies for the heavy tow in the hills. Either way you look at it you need to be down a gear or two and between 3600 and 5000rpm. Up there the old skool V10 needs some better air charge so this is the one time I recommend looking at one of the cold air kits.
As suggested earlier get a competent Ford tech to run a drivability diagnostic.
The age of the truck suggests that perhaps the IAC or other vacuum operated items my be weak or failing. some of the rubber "ell" connectors are notorious for deteriorating and causing all sorts of air leak grief. Most of the time they will manifest the problem with poor or uneven idle.
Don't know you economic situation but before sinking a ton of cash into the beast look into the extraordinary deals right now on 2001-2005 V10 powered trucks.
RPM wise... remember this is an overhead cammed motor and she pulls strong stable torque from 1900 rpm all the way to 4800rpm before going flat. The down side is screaming up a LONG steep hill at 4800 is nerve wracking for some folks and certainly costs a lot of fuel.
You folks with noticeable pingnig... if the PCM is not retarding and eliminating the ping there is a problem. I use mid grade 89 octane to delay the retard but there is absolutely no benefit from 90 or higher other than we accept you generous contribution to the economy.
Live2hunt.... ask very stern question of the trany re-builder about brand and type of trans fluid. I seem to remember a fellow a few years ago that the rebuild shop put straight no brand ATF in and it destroyed the 4R100. That trans is very picky about what TYPE fluid is used.
