351 Rpm
Old Jul 9, 2005 | 06:16 PM
5.8L95f150's Avatar
5.8L95f150
351 Rpm
how high will a stock 351 rev to?
Old Jul 9, 2005 | 07:22 PM
jroehl's Avatar
jroehl
The max I've ever seen on my tach (pedal buried) is 4400 rpm. That's in my '93 F250 with 351W, E4OD and 4.10 rear.
Jason
Old Jul 9, 2005 | 11:04 PM
SoCalDesertRider's Avatar
SoCalDesertRider
According to specs I have for my '92 351W, peak torque is at 2800 rpm and peak HP is at 4200 rpm. I would suspect redline to be between 5000 to 5500 rpm, but I've never tried to operate it at that speed.
Old Jul 9, 2005 | 11:28 PM
Blurry94's Avatar
Blurry94
I changed my shift points to 5350 for the 1-2 and 2-3 without any ill effects.
A stock can will start to fall on its face around 4500 which is probably why the rig shifts at that RPM.
Old Jul 9, 2005 | 11:45 PM
5.8L95f150's Avatar
5.8L95f150
will the rear gear matter?
Old Jul 9, 2005 | 11:51 PM
Blurry94's Avatar
Blurry94
A "taller" gear will make the motor ramp up faster, and on an E-tranny, your shift points may be altered because of this.
Old Jul 11, 2005 | 09:51 PM
handyman43358's Avatar
handyman43358
My 95 with a 351 doesnt show a redline at all on the tach. Goes all the way up to 6000 with no problem accoring to the tach. Although I've never revved it up above 3800 b/c it shifts before then unless I manually shift it. My shift points are real low, I've got a 3.55 rear end and 33 inch tires so im sure that plays a factor, cause when the speedo is maxxed out at about 90 or 95, im only pullin 2500-2600 in overdrive.
gettler
46
Dec 16, 2019 02:51 PM
Mil1ion
Oct 4, 2002 01:09 AM
351Inside
May 27, 2002 12:50 PM
frogger01
Mar 15, 2001 06:08 PM
AlM
1978 - 1996 Big Bronco
Mar 12, 2000 09:22 AM
