Sponsored by: Auxito
Diagnostic Codes
Old Jul 8, 2005 | 07:37 PM
cdawley1's Avatar
cdawley1
Diagnostic Codes
Hi,
I have a P0171 code on my 99 F-150 V6. I also have a Ford Service Manual on CD. Where are the OBDII codes located in the CD? I wanted to get some more information about it. I will be checking my MAF Sensor and vaccuum lines and will clear the code by disconnecting my battery. I read somewhere that it would be highly impossible for my O2 sensor to go out.
Thanks,
Chris
Old Jul 9, 2005 | 07:38 AM
projectSHO89's Avatar
projectSHO89
Look in the PCED, probably section 4.
Your statement about the O2 sensor is highly improbable. Maybe a typo?
Steve
Old Jul 9, 2005 | 08:42 AM
86moneypit's Avatar
86moneypit
The Code you pulled comes up as a "System Too Lean Bank 1" i hope that helps.
Old Jul 11, 2005 | 06:26 AM
cdawley1's Avatar
cdawley1
I cleaned my K&N air filter and the MAF section of my breather assembly really good and replaced both the pcv and the hose. I saw where the pcv hose was getting ready to crack when I squeezed on it. I reset my computer and drove the truck around locally for about 20 minutes and no light. I hope that fixed it.
Thanks,
Chris
Old Jul 11, 2005 | 06:22 PM
dcampbell511's Avatar
dcampbell511
I've also had this trouble code (1998 F150 4x4, 4.6L), sometimes one bank too lean, sometimes the other, sometimes both at the same time. Started out doing it at higher rpms so started by replacing the fuel filter, then the pressure regulator, then the fuel pump. Replacing the fuel pump made it run much better, but then the same trouble codes started coming up at low rpms, found the pcv hose at the back of the intake manifold slightly cracked, repaired it Saturday, replaced pcv valve, drove around for an hour, no light, wife drove it 10 minutes this morning and light came on. Haven't checked the trouble code yet, but suspect its the same. Next on list, clean throttle body and air by-pass valve.
Ken_C
Nov 22, 2012 11:52 AM
graeaglecrawler
Nov 18, 2011 02:10 PM
jc-well
Oct 11, 2009 05:23 PM
JmanOST8
Mar 28, 2005 09:56 AM
apairajeans
Escape & Escape Hybrid
Aug 29, 2004 08:23 AM
