Texture paint for rough firewall
Old 07-09-2005, 11:47 PM
Delzell's Avatar
Delzell
Delzell is offline
I used Zolotone under my hood to try and hide some patches. The painter sprayed it on but said it would not go on thick enough to hide the patches. So was he lying or will it no go on thick enough to hide a sheet metal patch?
Old 07-10-2005, 07:18 AM
uk1050's Avatar
uk1050
uk1050 is offline
paint
since i chopped my top i made a all metal headliner, i used splatter paint for trunks. got it at auto zone. hides all inperfections and can be painted. works great. cheap. comes in rattle can.
Old 07-10-2005, 03:11 PM
bluffdalian's Avatar
bluffdalian
bluffdalian is offline
Cleanings??
Originally Posted by 51ford fan
Ok, the pictues are in my Gallery. The running boards should be good for another 54 years LOL
How easy do you think it will be to get and keep them clean when you get dirt or mud on them?
Old 07-10-2005, 03:20 PM
51ford fan's Avatar
51ford fan
51ford fan is offline
I had Rhino liner installed in an F250 several years ago. I cant remember ever having any cleaning problems that a garden hose and nozzel couldn't remove.
Old 07-11-2005, 05:26 PM
51ford fan's Avatar
51ford fan
After putting that Herculiner coating on my firewall I drove my truck for the first time today. The starter and engine was so quiet I thought the battery was going dead, I put the charger on it just to be sure. It is ok, guess the coating just made it that much quieter.
Old 07-12-2005, 04:07 PM
xfordman's Avatar
xfordman
xfordman is offline
OK...I bought a spray can of Duplicolor for the firewall. The can said paintable, but there were no instructions. (scuff, primer, etc.) So I called the customer service and they said that the heat under the hood would make it peel. Has anyone had a peeling problem with any of the bedliner coating?
Old 07-12-2005, 09:31 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
I went the same route as "jet jock" except I had the body shop guys do it because I didn't have the tools. It looks good! Total investment $100.
Old 07-12-2005, 09:36 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,882 Likes on 1,856 Posts
I filled the holes in my firewall (there were many) and ues a little body filler and sprayed on rustoleum primer and satin black paint as a temporary band-aid so that it would look quasi decent until I could blow the truck apart for bodywork and paint sometime in the future. (there are pics in my gallery)
I like the thought of the rhinoliner as undercoating, its amazing stuff and hard as he**. I've seen it used in the oil field on the rig floors of drilling rigs.
Thanks for the tips
Bobby
Old 07-13-2005, 07:47 AM
51ford fan's Avatar
51ford fan
The Herculiner instructions say once it's on forget trying to remove it. So if anyone is thinking about using it, besure that rough texture is what you want.
Rod
Old 07-13-2005, 08:34 AM
hiball3985's Avatar
hiball3985
hiball3985 is offline
DELZELL...there probaly isn't any paint or coating that will cover a patch that isn't flush with the surface you patched..I don't know what kind of patch you have but your painter may be right....Hey you live in my area, good to see someone localy here
Old 07-13-2005, 06:41 PM
4t8-f1's Avatar
4t8-f1
4t8-f1 is offline
f.y.i mcmillan fiberglass makes a engine side firewall cover for about 125.00 i think i have one but havent got far enough along to use it . it is paintable if you desire 4t8-fi
Oldguyfl
03-21-2017 04:55 PM
munireusa
11-03-2016 04:25 PM
drewduncan15
03-21-2012 10:12 AM
phoneman91
02-28-2010 08:46 AM
svooom
06-18-2005 12:01 PM
Quick Reply: Texture paint for rough firewall
