Offroad & 4x4
spools vs. lockers
Old Jul 21, 2005 | 02:35 PM
fishmanndotcom's Avatar
fishmanndotcom
Originally Posted by poffutt
I have ARB air lockers both front and rear once they are locked you can not even turn on the pavement. They are locked solid I guess just like a welded spider. If I put on the rear ones I can turn, but I can fill my rear in jumping and churping.
yup its just like having the spiders welded but you can turn it off! it'd be nice to have selectables but welded spiders are jsut so much more simple and less to break
-cutts-
Old Jul 21, 2005 | 02:47 PM
MBBFord's Avatar
MBBFord
Welded spiders are more simple and CHEAPER. ARB lockers are real nice, but are way out of my price rainge.
Old Jul 21, 2005 | 05:30 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
selectbles are definitly starting to come down though!! you have the arb, e-locker, electrac, the ox locker(well you used to could get it), and the new t-locker. I got a price on an arb and an e-locker for my front 60 th othe day.... 586 for an eaton e-locker, 695 for an arb, and 469 for detroit. seems like with all the different selections now, the prices are coming down(still way high) . Im tring to find an open carrier for my sterling rear, so i can weld it and ell the detroit to help py for a front selectable.
MAN i wish SOMEONE would make a dang spool for the sterling!!!!!
Old Jul 21, 2005 | 07:09 PM
Thomsen's Avatar
Thomsen
I have heard some bad things about the e-locker Kubota...I would go with the ARB
Old Jul 21, 2005 | 07:25 PM
76fordtruck's Avatar
76fordtruck
Originally Posted by MBBFord
Yeah that explains it, lockers let the outside tire slip so they don't spin out on the road like a spool does, because axle is compleatally locked with a spool and when one tire needs to role more than the other it will, causing the tire wear and wear and tear on your gear.
Mini spools completally lock the axle like a spool, but is much weaker, and when it's put in a bind, it will break.
inside you mean? sorry to correct you..
Old Jul 21, 2005 | 08:23 PM
KubotaOrange76
i
i thought it was the electrac that had problems??? cause it has that big chunk sticking out on front of the diff, kinda like the t-locker
Old Jul 21, 2005 | 09:12 PM
Thomsen's Avatar
Thomsen
HAHA...you are right...got the two mixed up, sorry bout that
Old Jul 21, 2005 | 10:03 PM
MBBFord's Avatar
MBBFord
Sorry 76fordtruck, I just wasn't thinking.
Old Jul 22, 2005 | 12:21 AM
mustange70's Avatar
mustange70
To bad the OX locker wasn't picked up by someother company (i think they are still makin them, unsure of the sompanies fate though), but the cable ativation is the best way i think, no air lines or wires to tear up, granted the cable is still there but its a heck of a lot stronger then an airline.
Old Jul 22, 2005 | 04:10 AM
KubotaOrange76
yea, i wish i could find out if ox is in buisness or wut happened, noone seems to know
Old Jul 22, 2005 | 09:46 AM
Thomsen's Avatar
Thomsen
The only thing about the ox locker is that the cable can get gummed up with mud and dirt and then is hard to engage...but other than that it sounded like it would work pretty good
Old Jul 22, 2005 | 11:16 AM
mustange70's Avatar
mustange70
Good point, but it doesn't take much to rip an air line or wire off, and at least it can still be engaged.
Old Jul 22, 2005 | 11:58 AM
  #28
Thomsen's Avatar
Thomsen
True...but the cable on the ox locker could be ripped off also
Old Jul 22, 2005 | 12:22 PM
  #29
MBBFord's Avatar
MBBFord
It could still be ripped off, but not nearly as easy.
Old Jul 22, 2005 | 12:52 PM
  #30
KubotaOrange76
but if you do rip it off or break something on it, who are you going to call??? I plan to run the wires on the e-lockeralong the axle over to the leaf spring and up it ways, then to the frame
