The emissions light on the dash of my 86 F-150, 302, is lit. Code reader gave me a 122 (throttle position sensor voltage too low) I hooked up a volt meter and it reads .92 volts and when I push down the accellerator it goes up but comes back down to 1 volt with accellerator held down. Should I tyry to adjust the TPS to proper voltage or just replace it? Also, I adjusted the idle a couple of times before I found out you are not supposed to adjust it. Does adjusting the idle cause a problem with the TPS?? My dash light did not come on for several weeks after I adjusted the idle. The truck runs fine, just has a light on the dash.
That light is just a reminder light. In your owner's manual there is a way to reset it. It comes on every once in a while as a reminder to check over your emissions equipment. It was was just convenient that you had a code stored in your memory at the same time.
You're pretty addicted to FTE aren't you Matt? Posting so early in the morning....
Anyway, you're saying the emissions light is just a reminder to check emissions equipment and doesn't work as a check engine light to signal that there are codes? Do these trucks have a check engine light anywhere?
"emission" light says that its time to check out emissions system. Doesn't mean a fault of any kind. Pulling the bulb works I guess. But you actually suppose to reset the module. The module is under the dash, just to the left of steering column. Once you find it, it should have a hole in the side with a sticker that says"reset" (sticker may have fallen off). Find something that fits in the hole. While the reset button is depressed turn ignition to run, wait 5 sec.'s, then release reset. Should have done it.
HA! That was about 3 minutes after I woke up. Then I had to go to work.
There is not a check engine light on these trucks. I don't think the light comes on the trucks until 87 or 88.
You will just have to check the codes when you think something is wrong or (like I did) every oil change.
