front callipers...what a "drag"
Old Jul 5, 2005 | 08:43 PM
Blkbstr's Avatar
Blkbstr
(94 E-150) I had front wheels in air, I couldn't hardly turn by hand w/wheel on. took calliper off, turned great! Should I put NEW calliper on? ,or "kit" the old one? Is it hard, or easy?
Old Jul 5, 2005 | 09:37 PM
Wiskey6's Avatar
Wiskey6
Should just be able to pick rebuilt ones at the auto parts store at a good price.
One of the old Dodges I had, had rust on the cross shaft that went through the brake pedal arm, and it would cause the brakes to not release.
Old Jul 5, 2005 | 10:56 PM
85e150's Avatar
85e150
My '85 had plastic pistons, according to the brake shop fellas. The rebuilt them with steel, and did some other work, and wow, it's great to have brakes. If you can find a good brake shop, swap 'em out with rebuilts, I guess.
Old Jul 6, 2005 | 06:22 PM
Blkbstr's Avatar
Blkbstr
callipers it is!!!
Hey, thanks for the come back! Turns out, the core is worth almost as much as the rebuilt! Parts guy said to replace the brake line too...$24.oo per side. Total cost both sides=$68.00. Rebuilt-$47.00 They give me $40.00 for old one, $50.00 for both lines.Not bad if I do say so myself!
Old Jul 7, 2005 | 12:18 PM
Wiskey6's Avatar
Wiskey6
How do they feel now?
Old Jul 7, 2005 | 02:30 PM
maples01's Avatar
maples01
I worked on a vehicle once that the brake line let the fluid into the caliper, but not out, the fluid remained trapped in it, locking the brake. I replaced the caliper first, did not do a thing to correct it, had to go back and replace the brake line, you need to have the rotors checked now for premature wear.
Old Jul 7, 2005 | 05:26 PM
Blkbstr's Avatar
Blkbstr
Well, I havn't had time to do it yet. I think I'll do it Fri. I just know how much it will cost!!! Your right, I'm gonna do the line while I'm at it. Thanks for the confirmation.
Old Jul 7, 2005 | 06:43 PM
Gene W's Avatar
Gene W
Wiskey6,
You can check to see if it's just the line by opening the bleeder valve and then pushing the piston back in with either a tool made for that purpose or a large pair of channel locks over a small block of wood. The caliper may be ok. The lines will deteriorate inside and form sort of a flapper valve that will let fluid go to the brake but block it's return, like Maples was talking about. I have had that happen too.
You may find that the caliper seal is cracked and torn from the heat generated by the brake. My '94 has steel pistons but they can corrode if you never change the brake fluid or get gunked up and begin to stick if the boot is torn.
Clean up all of the rails and their mating surface on the caliper and lubricate with synthetic brake grease.
Of course you can't go wrong by just replacing all of it, but if you have the time to mess with it some, you may be able to narrow it down and save a few bucks.
Gene
Old Jul 8, 2005 | 02:40 PM
Blkbstr's Avatar
Blkbstr
Boy, did I feel foolish when I went into the parts store!!! I found out that total cost per side was $79.00, not $38.00 like I thought! I don't know what that 1st parts guy was talking about. Oh well, it will still be done.
Old Jul 8, 2005 | 05:44 PM
Blkbstr's Avatar
Blkbstr
I got the line and the calliper on now! Minus all the running around I had to do, it took about 1 1/2 hours. It don't squeak as much now either! It still don't free wheel quite as easy as I thought it would...oh well.
Old Jul 8, 2005 | 05:53 PM
maples01's Avatar
maples01
Rotor could be warped, or bearings are shot, "Check those bearings!"
Old Jul 8, 2005 | 09:30 PM
Wiskey6's Avatar
Wiskey6
As long as there is no pulsing when they are applied, they should be fine.
I just did new pads and turned the disk, and they do not turn easy w/the caliers on.
It rolls and breakes just fine.
Gotta R&R those outer plastic caged wheel bearings now....
Old Jul 9, 2005 | 05:43 AM
VikingBabe's Avatar
VikingBabe
Yes, check those bearings while you are at it! Did this a couple of weeks ago with my 82 because they were making noise. They needed replacing (nothing was there in teh Driver's side and the bearings dropped out of the cage on the Passenger side)
In the meantime, my husband replaced both brake hoses as the rubber was cracked/rotten surrounding the cord. He had to make a key spring for one caliper as we could not find any at the local parts store.
Old Jul 9, 2005 | 07:01 PM
Blkbstr's Avatar
Blkbstr
Thanks for all the input! Two yrs ago I repacked the bearings on both sides. How often should a guy...(or gal!) pack the bearings?
bryansshort
15
Sep 4, 2024 04:13 AM
MotoStrada
Jan 2, 2015 08:15 PM
frittingles
Apr 16, 2014 04:50 PM
fl-mitchells
16
Mar 15, 2013 01:43 PM
3wheeler
Jan 13, 2008 12:26 AM
