88 f150
Old Jul 5, 2005 | 07:50 PM
mmakela13's Avatar
mmakela13
88 f150
88 f150 will not shift into overdrive after changing timming chain and gears and valve cover gaskets heeellllpppp!!!!!!!!!!!
Old Jul 5, 2005 | 07:54 PM
Beast12's Avatar
Beast12
You may want to head down to this forum: https://www.ford-trucks.com/forums/f...splay.php?f=28
Make sure you tell them what engine, tranmission and year of the vehicle is.
Welcome to FTE!
-Matt
Old Jul 6, 2005 | 12:40 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum, have fun!
Old Jul 6, 2005 | 09:06 AM
SoFla David's Avatar
SoFla David
first check the obvious stuff like the Battery terminals. Loosen them and clean the terminals and battery posts, then put them back on and try again.
If that doesn't work, then start checking fuses.
Finally, check the fusible links right next to the battery and starter solenoid.
If it ends up being a fuse or fusible link... you have to try to find out WHAT casued it to burn in the first place... If you just replace it, it may happen again.
88_Lariat F-150
Jul 11, 2003 10:57 PM
michaelskerrett
Jan 13, 2003 09:51 PM
Brian460
Nov 5, 2002 04:48 PM
RGAZ
May 15, 2001 01:56 AM
PAUL_2
Dec 12, 2000 01:25 AM
