Yes, you can adjust caster!
Old Jan 9, 2003 | 09:52 AM
beartracks's Avatar
beartracks
...I'm too lazy to write a tech article but here is some nice info to file away in case you ever need it. After lowering my truck with A.I.M. industries 3" drop "I" beams I found I lacked caster on the left side and had a pull. Here's how it was corrected.
Stempf part no. 4410 contains two small cams. Remove the spring perch bolt and enlarge the bottom hole in the strut arm to 1". Reassemble with the cam in the hole and turn it to adjust camber! Then tighten the spring bolt. I attained a 1 degree increase in camber.
Old Jan 9, 2003 | 10:59 AM
Torque1st's Avatar
Torque1st
Posting Legend
Thanks again Bear Tracks!
Thanks for using FTE!
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID75&conf=genconf |Garage and Shop] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID116&conf=DCConf ID9|Ranger] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID91&conf=DCConfI D12|1973-1979 Ford trucks] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID93&conf=DCConfI D8|1997-2003 F150 and E150 Forum]
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Jan 10, 2003 | 09:47 AM
bigf150's Avatar
bigf150
Also another thing when you go the opposite way when you lift trucks you can get offset c bushings to put in the radius arms to correct the caster. Most lift companys sell them and energy suspension makes a set of them.
Old Jan 10, 2003 | 10:47 AM
beartracks's Avatar
beartracks
10-4. The cams only work for 2 wheel drive twin "I" beam.
Old Jan 10, 2003 | 12:12 PM
460429_freak's Avatar
460429_freak
Midnite1987
16
Mar 1, 2012 09:48 AM
shuttlevalve
Aug 18, 2008 10:55 AM
95f150
May 13, 2005 08:41 PM
Cor
21
Sep 8, 2004 02:46 PM
