Extreme Adjustable camber caster bushings
Old Feb 29, 2012 | 06:26 PM
Midnite1987's Avatar
Midnite1987
Ok I put the 2" spring spacers in my f150 and just got the extreme adjustable camber caster bushings.
My question is where should I set them when I put em in? I'm going to put them in myself before an allignment but I might have to drive it a day or two before I can get in for an allignment.
Anyone know where I should set them?
Old Feb 29, 2012 | 06:30 PM
Diesel_Brad's Avatar
Diesel_Brad
Put them in but dont put the nut on. Put the tire on and set it on its own weight. See how it looks. Adjust accordingly. Take into account for spring settle
Old Feb 29, 2012 | 06:31 PM
Midnite1987
On another note I HATE the stupid foam packing peanuts....
Old Feb 29, 2012 | 06:33 PM
Midnite1987
That makes sense but what about the caster?
Old Feb 29, 2012 | 06:36 PM
Diesel_Brad
Just make them lean back a lil(more caster)
Old Feb 29, 2012 | 06:42 PM
bashby's Avatar
bashby
When I did alignments I used to HATE those adjustable bushings. They are really hard to remove after they have been installed for any length of time. The alignment tech would probably prefer you reinstall the fixed ones. The procedure is: hook up sensors to get caster/camber readings, remove old bushingsto see what deg offset they are, then calculate the bushing you need to get it in spec. If a fixed bushing can get the job done I'd go with that... they are way cheaper. If you replace with adjustable bushings the tech will have to try to remove them without breaking them up too much to be reused, then refer to the chart to figure out where they are set then calculate the change needed and refer to the chart to figure where to set them.
Old Feb 29, 2012 | 07:04 PM
Midnite1987
i already have the bushings to do it and i dont want to pay the allignment shop to change them as it would be a $300 allignment
Old Feb 29, 2012 | 07:14 PM
Midnite1987
Is it back? I was thinking forward or some reason
Old Feb 29, 2012 | 07:29 PM
bashby's Avatar
bashby
iT SHOULDNT COST $300 but it does depend on your area. Do you still have the old bushings in there?
Old Feb 29, 2012 | 07:51 PM
Midnite1987
I haven't touched it yet. I was told It starts at $150 for a basic allignment and it's $96/hr To do the bushings
Old Feb 29, 2012 | 08:06 PM
bashby's Avatar
bashby
WOW, I wish I made that much doing them. I think about 4 years ago the last on I did we got 49.95 for a FEA, and .8 hrs/side on the bushings at 75/hr. Anyway, If you want to try to do it yourself I'll try to help. You first need to figure out what your camber is now. You'll need a level area to work on. A camber gauge would be a huge help but I imagine you could do it with a level and a protractor of some sort or another way to figure the angle of the wheel. I recomend getting the toe in close before taking measurements because if its way out it will effect the camber. You need to drive forward onto the level surface and stop without backing up, then take your measurements as backing up will throw it out. As far as caster goes, I'd just set it to about the same as the old bushings had it set at... maybe a little more +caster.
Old Feb 29, 2012 | 09:46 PM
jborushko's Avatar
jborushko
...firestone life time alignment $170
i hate firestone but life time alignments... hard to beat
Old Mar 1, 2012 | 12:15 AM
Midnite1987
My iPhone has the level that shows the degrees.
I'd want the camber as close to 0 as possible right? Is it better to be a little off on the +or- side?
Old Mar 1, 2012 | 12:33 AM
Midnite1987
Just for comparison sake
Rear wheel where the truck is parke now
Front wheel where currently parked
Going by that the fronts about 4.5degrees out from the rear....
I'll check it again if I can find a level road tomorrow
Old Mar 1, 2012 | 06:31 AM
bashby's Avatar
bashby
Try to get about .5 deg positive camber
