Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Brake Problems
Old Jul 4, 2005 | 12:25 PM
alycat's Avatar
alycat
Brake Problems
I have a 2003 ford escape, that I bought new. I have had the worst problem with my brakes. I put brake pads on in September and now I just put new rotors on about a month ago. The pads were still good. I have now noticed that my brakes grind and sqeel. It doesn't happen all the time and it is hard to pinpoint just when it does it the most. Has anyone else had this problem or can anyone give me any advice on what to do. I know I need to repalce the brakes and rotors but any onther info would help.
Old Jul 4, 2005 | 05:24 PM
Beast12's Avatar
Beast12
Did you do all this work? Did you get the brake parts from Ford? You may want to get a good aftermarket pad and maybe some better rotors.
A good brake shop in your area might be able to help you out on good quality parts.
Good luck and Welcome to FTE!
-Matt
Old Jul 26, 2005 | 11:00 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
If I recall correctly some pads aren't compatible with the original rotors, and vice verse.
Old Jul 27, 2005 | 06:10 AM
alycat's Avatar
alycat
I have replaced both pads ond rotors, but I did it about 4 months apart. My father tells me that I am crazy because he doesn't here it but I know what brakes are suppose to sound like and good brakes are not suppose to grind (seems like it does it most when it is hot or the brakes are hot. I am thinking I will just replace the pads and rotors again since theyt are both under warranty, then pads and rotors will be new, then if there is still a problem, I will take it to the dealer. Thank You
Old Jul 27, 2005 | 06:28 AM
EBTDM's Avatar
EBTDM
How are the rear brakes? Have you looked at them lately?
Old Jul 27, 2005 | 06:38 AM
alycat's Avatar
alycat
no, i have not done anything with my rear brakes, but they don't seem to have any problems, that I have noticed. do you tink i should check them out?
Old Jul 27, 2005 | 12:02 PM
EBTDM's Avatar
EBTDM
Yes, that slight grinding you hear may actually be coming from there. How many miles are on them?
Old Jul 27, 2005 | 03:36 PM
87 XLT's Avatar
87 XLT
If you stop it with the E-brake do you hear the noise?
Old Jul 28, 2005 | 07:23 AM
EBTDM's Avatar
EBTDM
I tried that a couple times. A very fine line between slowing the tires and stopping the tires. Could really hear the the tires sliding on the pavement though. Better to just do a rear brake inspection. Only takes about 15 minutes with a floor jack and lug wrench to do both (one at a time of course).
Old Jul 28, 2005 | 12:57 PM
alycat's Avatar
alycat
They have less than 5,000 miles on them. I will check out the rear brakes and let you all know. thanks
Old Aug 24, 2005 | 11:29 PM
mdntblu's Avatar
mdntblu
I have an 01 escape and have ran into the same problem. I replaced the rotors and pads at 40,000 miles and now they are already grinding and it's only got 64,000 miles on it now. I replaced them with Ford ones too. So maybe it's time to spend some extra money and buy aftermarket rotors and pads.
Old Aug 25, 2005 | 07:06 AM
EBTDM's Avatar
EBTDM
How are the calibers? Could they be hanging?
Old Aug 25, 2005 | 07:21 AM
alycat's Avatar
alycat
I have taken my escape to the dealer and they tell me that there is nothing wrong with them. I think I am just going to sell the car, as much as I love it. There is now a recall on the 01-05 escapes because of a defective excelorator cable. Your car will literally take off on its own and that causes the brakes to fail. A woman in my city had this problem after she had the cable replaced by the same dealer I baught my escape from, the car would not stop and was excelorating on it own (the cable gets stuck). She didn't know what to do going 60 mph in a very busy intersection, so she jumped from the car, and died of a head injury. I know that it could happen to any car but there is apparently something else wrong that Ford needs to look at. NOw I don't think I would jump from the car at that speed but. You may want to get yours checked if you haven't already. I Think I will just put cheap brakes on it for the time being and trade it in for something else because I have never had a problem like this with brakes on any of the cars that I have owned, and I have wasted alot of time and money just on the brakes.
Old Aug 27, 2005 | 11:07 AM
bananaboat's Avatar
bananaboat
Actually, the cable recall is on the 01 through 04 model. The notice can be found at the NHTSA website.
Old Sep 12, 2005 | 08:54 PM
Nateid15's Avatar
Nateid15
I was just brousing, and came across the thread... I read it and have no techincal information to ad....
But who the heck jumps out of a moving truck, muchless at 60mph???
Why didnt she just shut it off???
Ok, dont flame me, but it sounds like darwin to me, and if this message is against forum rules, I will deleate it
~Nate
