Sponsored by: Kumho
leveling kit install...
Old Jul 3, 2005 | 01:37 AM
87carbed's Avatar
87carbed
i just picked up a front 2" leveling kit from suspension connection here locally, and i was wondering, how much do you guys think it would cost to install? i've got an 87 f-250 with the twin i-beam up front. thanks
Old Jul 3, 2005 | 01:58 AM
cpnhgnjnky's Avatar
cpnhgnjnky
Shouldn't be but maybe a little more than a shops price to change springs. It is a very easy thing to install, and should take less than an hour for the whole thing. I was able to install one for my friend in just under 45 minutes. Try reading over the directions, you don't have to be ASE Superguy to put these in, you don't even need a lot of tools. You can save money this way to buy something else to mod your truck.
CJ
Old Jul 3, 2005 | 03:53 AM
87carbed's Avatar
87carbed
thats what i heard, so no alm lifts or anything? can this be done in my driveway? what tools are required, and is it a 1 person job or more?
Old Jul 3, 2005 | 03:55 AM
87carbed's Avatar
87carbed
what would that price be btw?
Old Jul 3, 2005 | 04:19 AM
cpnhgnjnky's Avatar
cpnhgnjnky
Each shop has its own "by the hour" rates. However to make it look lower they sometimes list it in 1/2 hour. Most shops are $60.00+ per hour on up. You need to be able to let the suspension sag to relieve pressure from the front suspension. To place new springs or shims in my truck (Twin I beam) it takes a 9/16 wrench, and a 13/16 I believe for the bottom nut. If its a shim that slips over the top of the spring you only need the wrench. Either way you have to be able to take the pressure of the susp. A good jack w/ jackstands to the frame should work nice. Then its off you go. If your kit doesn't have directions in them, go on line w/ the manufacturer. If all else fails look at what you bought figure out where it goes and take apart what you need. You should remove the tire to make it easier to work on. You don't have to remove the hub assembly or anything like that.
CJ
Gbvb87
2004 - 2008 F150
Aug 2, 2016 08:48 PM
Gbvb87
Testing.....
Jun 3, 2016 06:10 PM
LPog
Dec 25, 2015 07:19 AM
BKM-WR3
Feb 13, 2015 12:57 AM
mrrish79
Mar 1, 2014 04:52 PM
