Remote hood latch/alarm componets
Old Jan 9, 2003 | 09:58 AM
beartracks's Avatar
beartracks
...I seem to have lost the search function again so I'll try a new thread. I'm installing a new alarm system and considering the remote hood latch. I could use some tips on part numbers for the latch and mounting and routing of the cable/**** etc.
...I'm also trying to decide where to locate the shock sensor and the proximitry sensors. Does it really matter if they are hidden or not?
...Faster than a speeding ticket!
Old Jan 9, 2003 | 10:57 AM
Torque1st's Avatar
Torque1st
Posting Legend
Bear, find a remote latch on a truck in the Junkyard and make notes as you pull it. Otherwise use bends with the largest radius possible.
I haven't got a clue on the alarm components.
Usually the search function is down temporarily, retry and/or try again later.
Thanks for using FTE!
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID75&conf=genconf |Garage and Shop] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID116&conf=DCConf ID9|Ranger] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID91&conf=DCConfI D12|1973-1979 Ford trucks] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID93&conf=DCConfI D8|1997-2003 F150 and E150 Forum]
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Jan 10, 2003 | 12:39 PM
orangeford's Avatar
orangeford
I am going to use my underhood light for the trunk hood trigger wire. If I can make it work. I already have a locking hood latch but this way if anyone ever gets it open it will set off the alarm.
Old Jan 10, 2003 | 01:41 PM
Mil1ion's Avatar
Mil1ion
Beartracks, I sent you a private e-mail.
Dennis
[i]F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/starfleet_command_e0.gif
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Jan 11, 2003 | 10:53 AM
unreng's Avatar
unreng
Bear,
The hood latch part number is e5tz16914a. The cable will work from 78 on up to the mid 80's I believe (I pulled some from 80's bronco's and they are the exact same length as 70's cables). Finding the latch is the hard part, but they are offered on e-bay every so often. Getting the lock keyed to the ignition key is not dificult ($20). The cable handle will attach to the left of the drivers courtesy light beneath the dash. The cable will extend through the firewall, directly towards the upper side of the washer bottle. It then extends toward and through a ~2" hole in the front radiator support and then to the latch. I can send some pictures if necessary from the 78 Ford shop manual. Good luck.
Chris
Old Jan 11, 2003 | 07:46 PM
Ford_Six's Avatar
Ford_Six
Old Jan 13, 2003 | 09:33 AM
beartracks's Avatar
beartracks
Thanks!!!
mhans311
Escape & Escape Hybrid
Dec 17, 2014 07:12 AM
oldgrayman
1947 and Older Ford Trucks
Nov 4, 2014 09:37 AM
ohbrian
Sep 23, 2013 01:05 AM
mlr51
Dec 30, 2002 05:02 PM
MO51
Dec 10, 2001 05:43 PM
