1986 ford won t start
Old Jul 2, 2005 | 07:38 PM
cbjr61's Avatar
cbjr61
1986 ford club cab truck won t start
was driving and truck died lots of gas but it seems like no spark
engine turns over no problem
what do i check please help truck is parked need it running
Old Jul 2, 2005 | 07:53 PM
Mike38's Avatar
Mike38
Hey welcome to the forum. The same thing happenned to me in my truck. Turns out the coil got soaked. If its not the coil then maybe a new distributor cap and rotor, even plug wires could be in order. Also, check to make sure all the connections are good, especially those on the cap on the coil, the alternator, or the distributor as they have a way of shaking loose. If it turns out to be none of those things, then the fuel filter might be plugged. Lastly, there might be a vacuum leak on the gaskets to your intake manifold or your carb/throttle body. Hope that helps.
Mike
Old Jul 2, 2005 | 08:05 PM
cbjr61's Avatar
cbjr61
how do you test the coil
Old Jul 2, 2005 | 08:08 PM
Mike38's Avatar
Mike38
You need 2 people, one to start the truck, the other to hold the coil wire to a ground and see if a spark jumps. If you have spark, no problems with the coil.
Mike
Old Jul 5, 2005 | 04:49 PM
cbjr61's Avatar
cbjr61
truck just want start could it be the module on the side of the distributor how do you test it
Old Sep 1, 2005 | 07:05 PM
bigcheese53's Avatar
bigcheese53
You Can Have Spark But Not Enough Spark. This Problem Happened To My Sons 1986 Ford F250. Turned Out To Be Coil.
Old Sep 2, 2005 | 03:46 AM
RR4E's Avatar
RR4E
Coil, spark control box, condenser, coil wire, ignition module...so many possibilities to check. Buy a Haynes manual, and a multi-meter, and start eliminating the parts that do work until you find one that doesn't.
The spark control box (mounted on the inner fender, silver or black square box, with wires running to the coil) is often the suspect for absolutely no spark. To be on the safe side, if you replace it, take it with you, or at least make a wiring diagram with the colors of wires and in their particular order on a piece of paper. Ford made several of these, some different colors cross over, but you have to be able to figure out if a certain other color of wire does the same job as the color scheme you have. It's easier to find one with the right color scheme(plug and play).
Coils generally out-live the vehical, the odd one falls prey to heat soaking. It wouldn't be the first part I'd suspect. The ignition control module on the side of the distributor is another part I'd lay odds on. If it were me, I'd check the control box and module first.
Old Sep 2, 2005 | 08:51 AM
lmadore's Avatar
lmadore
The box described above does not exist on an 86. 86 was TFI. Previous years used the box and it was called Duraspark ignition.
TFI module is on the side of the distributor. They tend to fail when hot, but I had one that just up and died one day. This part will take a special wrench to remove and you will have to loosen the distributor and rotate it to get to both fasteners.
If done correctly, you can avoid retiming the engine.
TFI is about $25. Tool is usually about $5 - $7 (can be bought at parts store).
Old Sep 2, 2005 | 03:55 PM
82F100SWB's Avatar
82F100SWB
TFI is not found on all 86's. The only definite TFI bearing engine is the EFI 302, there are lots of 86 DS-II ignited 300, 351W and 460's out there, and the 351W and 460 stayed carbed into 87, both with Duraspark ignition.
Old Sep 2, 2005 | 04:50 PM
lmadore's Avatar
lmadore
There is no reference to engine size or truck size in the original post.
The 5.0 was the most common engine produced in 86
Old Sep 2, 2005 | 05:09 PM
Ramrod48's Avatar
Ramrod48
well I had one the timing chain broke on it , no spark .,,, An yea lots of 86-87 have the dura spark 2 system ,,,SORRY !!!!!!
Old Sep 3, 2005 | 07:28 AM
truckfarmingcanuck's Avatar
truckfarmingcanuck
I agree with the module suggestions.
Another 2 second check while looking for spark is to ensure that the rotor under the cap is turning.
It's a nasty possibility. While doing spark checks just pop the cap off while someone is turning over the engine to make sure that lil sucker is turning in there. Rare yes..... Did it happen to me ......yes. Bottom gear of the dizzy chewed off a gear tooth or two.
Good luck
TFC
Old Sep 3, 2005 | 11:37 AM
RR4E's Avatar
RR4E
What engine is in this truck? I'm curious, as it could help narrow down the potential list of available options for ignition, etc.
The I-6 engines used timing gears rather than gear and chain sets, and they were nylon toothed and very notorious for spitting out teeth after as little as 20,000 miles.
ford1986f250hd
Jun 9, 2011 11:10 PM
Dkanngiesser
Electrical Systems/Wiring
Dec 13, 2007 07:54 PM
mouthahoy
Jun 9, 2004 01:53 PM
F800
Apr 23, 2004 07:08 PM
gary123
Jun 7, 2003 12:17 PM
