Alternator Alternitives
Old Jul 2, 2005 | 08:34 AM
66beater's Avatar
66beater
I went to start my truck this morning, and got the dreaded Click click clickity click!
I just replaced the wiring for the charging system a few weeks ago, and a carefull inspection shows it's still fine, I just have no juice. The altinator's bearings have squealed when it was cold since I bought the thing, and I figure its time to replace it.
I would rather do a single wire altinator conversion that put another lightweight unit in there. The part stores around here don't have listings for an alternator like that, and say they can't look one up unless they have the year and model of the vehicle I want. So what I need to know is what altinators I can use to beef up my system, and what cars or trucks used them? my goal is 80 amp but higher is fine
Old Jul 2, 2005 | 08:50 AM
jowilker's Avatar
jowilker
I think the one wire that you are referring to is a GM alt. that some guys have converted to.
Sounds like the battery is dead, get it charged up and drive the truck to your local parts house and they will test both the battery and alt. for you.
Alts. can be purchased with different outputes, however with nothing more than reg. equipment you don't need a high outpute unit. IMHO
John
Old Jul 2, 2005 | 11:22 AM
bluestang65's Avatar
bluestang65
In the 1980s ford used the same three wire units that even bolt in the same way yet they ahve a higher amperage rating. Rather than switch to the GM alternator, get a one wire kit from Summit racing or use a 3rd generation alternator from Ford. They are the best and have the highest amp ratings plus they have a built-in regulator. Not sure if there is a direct bolt in unit, but the one from a 1992 Ford Thunderbird is a fine unit and with very little modifications it should bolt in.
I would agree that the battery is dead, so your alternator might just be fine. Even those old school Ford alternators can get the job done for many, many years, so don't get too excited about trashing it - you might just be opening another new can of worms.
Old Jul 3, 2005 | 12:59 PM
hiball3985's Avatar
hiball3985
read this first..www.madelectrical.com you may have a different opinion of 1 wire alternators...made me rethink what I was planning
Old Jul 3, 2005 | 03:27 PM
66beater's Avatar
66beater
Battery tests good, Altinator is working fine now. But this has happened before, and the squealing bearings are enough reason replace it.
MAD Electric makes a good case for the three wire, but they seem to be trying to sell their kit. Still, 3 wire is better. Mainly for the advantage of an alt Light.
Not modifying my system would be nice. Do these 1980's altinators use the same style external voltage regulators as my 66?
Old Jul 3, 2005 | 04:19 PM
hiball3985's Avatar
hiball3985
can't help you with that, anything after 66 I'm lost,but I'm sure there are higher output alternators for use with external regulator
Old Jul 3, 2005 | 05:36 PM
44dwarf's Avatar
44dwarf
Jeg's and Summit NOW list a FORD 1 wire!! jegs part#555-10127 100 amp black 1 wire.
44dwarf
Old Jul 11, 2005 | 09:02 PM
66beater's Avatar
66beater
Thanks for the great advice advice, I decided to go with a Ford 3 wire. It ended up being my alternator. It being one of the 55 amp units, couldn't handle the load. The rating on an Alternator is it's peak capacity, but it only makes that at full RPM, and the waymost ratios on belts are, it never quite reaches full RPM at engine redline. thats due to the manufacturers trying to keep them from overspinning. The end result is an alternator making 40-50% of it's capacity at road speeds. Swapping to a bigger alternator will allow it to produce more at lower RPM, and let the alternator run cooler, so it lasts longer.
DL73031 is a 100 amp that almost bolts in. I had to make a bracket for the adjuster. I used a chebby 350 chome peice I found at Autozine for $10 and cut 4 inches off the non adjuster end. Its a perfect fit for the larger body alternator. As for the wiring, I had to crimp on 2 blade stlye connectors, but the posts are labled the same as the old unit, so wiring it was a no-brainer.
Now when I'm idling, my headlights don't get dimmer. I'll post pics once I get the wiring cleaned up.
mattb77
Sep 13, 2011 02:02 PM
1978fordf250
Jan 25, 2008 10:08 PM
Ken460
Electrical Systems/Wiring
16
Oct 28, 2007 02:55 PM
Fordbyford
Mar 24, 2006 12:52 PM
Greg21791
Mar 8, 2005 11:25 AM
