351m or 400
Old Jan 14, 2003 | 07:10 PM
Zachary Smith's Avatar
Zachary Smith
351m or 400
Hi
I have a 1978 f250 with a 351m/400 and I would like to know if it is a small block or a big block and if it's a 351m or a 400.
Old Jan 14, 2003 | 07:53 PM
Mil1ion's Avatar
Mil1ion
351m or 400
The designation is a 335 series engine.
Other wise known as a Small block with a Big block transmission bolt pattern.
Unless to have the engine Buck tag,You will need to figure out the stroke to know for sure.
Piece of dowel inserted into the sparkplug hole measuring twice.
TDC & BDC.
Dennis
[i]F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/starfleet_command_e0.gif
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Jan 14, 2003 | 07:58 PM
picuplines's Avatar
picuplines
351m or 400
[updated:LAST EDITED ON 01-14-03 AT 09:00 PM (EST)]go to bubbaf250.com they will show you how to locate and understand the I.D codes. take starter down you'll find a code D7TE this means 77 truck engine to find out if its a 351m or 400 take the oil pan down its the only way . 351m cast # is 1k or 1KA . 400 cast # is 5M or 5MA for a car and 5MAB for the 400 truck. these are stamped in the 1st counterbalance of the crank.good luck let me know how u do.
Old Jan 15, 2003 | 10:54 AM
tw's Avatar
tw
351m or 400
Old Jan 15, 2003 | 04:35 PM
rustynuts's Avatar
rustynuts
351m or 400
i have heard that the 400 has a thicker balancer than 351. the 400 is like an inch and a quarter wide and 351 is 3/4 of an inch.
Old Nov 29, 2005 | 05:02 PM
derherr65's Avatar
derherr65
351m or 400 id? on emmissions tag
The emmissions tag on the driver's side valve cover, just below the oil filler cap, tells you the displacement. It's on the top line of the tag.
Old Nov 29, 2005 | 05:07 PM
Torque1st's Avatar
Torque1st
Posting Legend
This thread is almost three years old. The question was dealt with LONG ago in a galaxy far far away...
bigredkacy
Jul 27, 2006 05:31 PM
bobbymcgee1980
Feb 4, 2005 09:46 PM
mirage820
Jul 30, 2004 03:32 AM
ethomps
May 14, 2004 09:03 PM
66ford400
Nov 17, 2003 09:09 AM
