Yes as long as he removes the programming from his truck. The SCMT stores the factory program when installing which vin locks it to that particular truck.
Yes, there are certain ones for certain trucks (engines). The one you will get will be for the 7.3PSD 1999-2003 (I do believe). I use the same one on my 2002. Only one truck can use the tuner at one time though.
The SCMT model 1705 will also work on earlier models of Power strokes, like 1996. It uses the VIN to identify the truck and puts in a program appropriate to it. The models without the intercooler, for example, will not get the same program or horsepower gain as the later models. Go back to the page for this forum that lists all the threads and check out the first page of the thread about the superchips. Down a few posts is the information about the 1994 to 1998 models.
WArren
as long as the tuner hasnt been used on your buddys truck it should work . iit was my understanding once it has been used on one truck cannot be used on another one.
