Emissions Test
Old Jun 30, 2005 | 08:37 PM
Hypoid's Avatar
Hypoid
Originally Posted by krewat
Beyond all that, if you want to try it again, do a complete tuneup (cap/rotor, wires, plugs, pcv valve, filters, etc), setup the idle screws, idle speed, point dwell, etc correctly, and see if it flies this time.
There ya go! Start at square one, make certain the ignition is at spec.
What ever your manual gives for timing, add 1* for every 2000 feet above sea level. A better manual (I wonder if my brother still has those...) will state this in the footnotes.
Short of an EGA, using a vacume guage to find "best lean idle" is very effective:
Begin with the engine at operating temperature, curb idle, idle screws indexed at 1 1/2 turns out (reference point). Vacume guage attached to manifold vacume. Alternating from side to side, turn idle screws in 1/8 turn at a time, wait a few seconds after each adjustment. When vacume drops, back out that screw 1/8 turn, continue with other screw to do the same.
If vacume drops right away, (from 1 1/2 turn index) back out screws to achieve highest vacume reading, begin procedure from there.
The only other advice I can give is to have a fresh oil change and the engine at operating temp when you go for the test.
Taking this much time and having this much patience got my tired 390 through emissions when it should have failed the visible smoke stage. (full synthetic oil doesn't burn ) The perk is that you have a "happy motor", which makes for a happy driver.
BTW Bear, how expensive are houses in your area? Any financial opportunities for a gearhead-at-large? LOL
Old Jun 30, 2005 | 08:49 PM
fordeverpower's Avatar
fordeverpower
Converters didn't even come out till like 1974 or so. Of course california was most likely first. I like living in Iowa. (Ohio is gay!)
Old Jul 1, 2005 | 09:43 AM
EgoMan's Avatar
EgoMan
Well I have to take my 68 in but it doesnt have to pass anything. the test on a 68 is so low that if you dont pass your engine is shot and probobly puffing smoke. If you have a crusty carb and stock manifolds it will hurt your test, dont know why it just does.
Old Jul 1, 2005 | 09:58 AM
Mike G's Avatar
Mike G
Originally Posted by jor
Here's what I do every year to get my 67 352 to pass in Arizona:
* Timing at 5° BTDC (normally it's 8)
* Very lean fuel
* New PCV valve
* Add one gallon of denatured alcohol to 1/2 tank fuel ($9 per gal)
* Set the idle a couple of hundred above normal (maybe 875 or so)
I always feel as though I have gotten away with something when I pass and I usually celebrate with a cold beer. Good luck.
jor
___
I always make sure to do the fresh oil change too. Then I visit my favorite emission shop that is owned by a drag racer. After a little BS'n, he always tells me "don't worry, we'll get it there".
--Mike
Ray620
Jul 21, 2012 06:50 PM
JB-1
71
Jun 23, 2012 09:32 PM
chrisvanhoog
1978 - 1996 Big Bronco
Apr 24, 2012 01:39 AM
BAD RONALD
Mar 7, 2012 08:16 AM
Pest007
31
Oct 10, 2008 08:18 PM
