Emissions Test
Old Jun 29, 2005 | 05:40 PM
RA042926's Avatar
RA042926
Banned
Emissions Test
I have a 68 F100 with a 390 and a 2 barrel carb. I recently had to have the emissions tested, and unfortunately failed the test. My Carbon Monoxide output was to high. Any ideas what I can do to fix this? I recently rebuilt the carburetor. Would having the mixture set wrong cause this to fail? Would fuel additives possibly cause problems? Any hints, tips or advice would be very much apprecited!
Old Jun 29, 2005 | 05:49 PM
rusty70f100's Avatar
rusty70f100
Lean it out, that should fix it. If it fails at idle, lean it out a little there, if at speed stick some smaller jets in it.
On another note:
Since when does a 1968 truck have to get emissions testing??? That's rediculous, do some research on your laws.
Old Jun 29, 2005 | 05:56 PM
RA042926's Avatar
RA042926
Banned
Yeah, I was pretty surprised to get the notice that I had to do it. I will look in to it. I appreciate the advice... Thanks.
Old Jun 29, 2005 | 05:59 PM
RA042926's Avatar
RA042926
Banned
It was the Idle test that failed, by the way. I will try leaning the mixture a bit and see what happens...
Old Jun 29, 2005 | 06:13 PM
Bear 45/70's Avatar
Bear 45/70
Do like I did, when the 428CJ wouldn't pass anymore, I moved to where there is no testing. My stress level dropped by 75 percent also.
Old Jun 29, 2005 | 11:03 PM
RA042926's Avatar
RA042926
Banned
Well, I sort of like where I live, other than this inconvenience...
Old Jun 29, 2005 | 11:52 PM
Bear 45/70's Avatar
Bear 45/70
I now live in an unincorperated town on Hood Canal with a view of the Olympic Mountains and Hood Canal out the front windows. I can hunt in my backyard (Deer, Bear and Elk in the western part of the county) and fish in my front yard along with crabs, clams, oysters and shrimp. Ride my quad from the house into 4000 acres and over 200 miles of roads and trails. And no emissions test at all.
Old Jun 29, 2005 | 11:57 PM
EgoMan's Avatar
EgoMan
I cant stand emissions tests... In california were at i think 74 or 76...right in there is the cut off.
Old Jun 30, 2005 | 09:46 AM
Mike G's Avatar
Mike G
I could have been your neighbor 20 years ago
Here in Colorado, the pre-1981 cars are tested differently, but you still need it for plates. On the "classics", you can get 5-year plates so it's not too much of a headache.
--Mike
Old Jun 30, 2005 | 10:13 AM
jowilker's Avatar
jowilker
I had a car that wouldn't pass a few years ago, a mechanic adjusted the idle rpm down and it passed. go figure
Can't believe a 68 truck is being tested. Some of the states that require testing of old vehicles can opt them out if it would take a lot of money to correct it.
I might look for another shop if that option is available.
John
Old Jun 30, 2005 | 10:50 AM
gtex's Avatar
gtex
ya might try some Super Unleaded.....if not already.
Old Jun 30, 2005 | 11:45 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Carbon Monoxide is the result of inefficient combustion. If you passed on HC's, that probably means you are already running lean.
Without a hit-or-miss approach, the only way to get the carb right is to find an exhaust analyzer, or shop that has one, and adjust the idle mix screws until you get a low-enough CO ... Be careful, you can send the HC's way up too.
Since it's an idle test, main carb circuits do not come into play (or shouldn't, if the power valve is good). The idle screws are what you need to play with.
I've had the same problem before, and the only way to get it right was with an exhaust analyzer.
Beyond all that, if you want to try it again, do a complete tuneup (cap/rotor, wires, plugs, pcv valve, filters, etc), setup the idle screws, idle speed, point dwell, etc correctly, and see if it flies this time.
Here in Metro NY, we don't need to be tested after the car is 25 years old. Just safety.
Old Jun 30, 2005 | 01:00 PM
FalconStng's Avatar
FalconStng
I can't believe you'd have to pass emissions either. If so, you might not get it. High CO can be caused by engine problems that a tuneup won't fix. What CO specification do you have to meet and what was your actual output? Usually if it's a worn engine then the CO will not even be close to passing.
Old Jun 30, 2005 | 01:45 PM
bshackelford711's Avatar
bshackelford711
you are worried about emissions and i dont even have to worry about having my truck inspected
Old Jun 30, 2005 | 02:57 PM
jor's Avatar
jor
Here's what I do every year to get my 67 352 to pass in Arizona:
* Timing at 5° BTDC (normally it's 8)
* Very lean fuel
* New PCV valve
* Add one gallon of denatured alcohol to 1/2 tank fuel ($9 per gal)
* Set the idle a couple of hundred above normal (maybe 875 or so)
I always feel as though I have gotten away with something when I pass and I usually celebrate with a cold beer. Good luck.
jor
___
