New gauges
Old Jun 29, 2005 | 02:53 PM
77mudder's Avatar
77mudder
New gauges
Anyone know if i can put aftermarket gauges in my 77HB? I'm talking a whole swap, speed, fuel, all of it> If so any ideas on where i can start looking. It is a mud truck so nothing to fancy just something that works
Old Jun 29, 2005 | 05:43 PM
bigf150's Avatar
bigf150
Auto meter sells sweet gauges for every need possible. My truck has oil pressure and water temp on the cowl outside the truck and im gonna put a 5 inch tach with shift light on the steering column. I may also add a tranny temp gauge.
Old Jun 29, 2005 | 07:33 PM
ivanribic's Avatar
ivanribic
Is there any particular reason you want to swap all your guages? There are a lot of options. I'm a big fan of the Autometer guages like bigf150 mentioned but they're not cheap. When you say you don't want anything too fancy, just something that works I the first thought that comes to mind is: stock guages. What are you looking to spend and what guages in particular do you want in your truck?
Old Jun 29, 2005 | 11:26 PM
MBBFord's Avatar
MBBFord
I agree with Ivan go with stock gauges, if yours are messed up get a gauge cluster out of a junkyard truck, and you could look on summit racing.com for many diff. brands, and you can choose your price range to search through them. I have a 3 3/8" equus tachometer, that works great, and got it for $30. Summit has their own brand that seems just as good. You might want to look for a fuel gauge to, cause the stock one is horrible. You can get a set of a triple gauge set up, with oil temp, amp, etc.....
Good luck, with the search,
-Matt
Old Jun 30, 2005 | 06:59 AM
77mudder's Avatar
77mudder
thanks for the info, I think i am going to go with stock, and your right, my fuel gauge only works on rough roads
Shooter00
13
Dec 23, 2011 08:29 PM
kuch73
Oct 20, 2011 01:10 PM
tolie77
Mar 17, 2010 08:28 PM
olblue76
Apr 13, 2006 10:36 AM
f100tk77
Apr 13, 2006 08:17 AM
