Sponsored by: Auxito
misfire
Old Jun 29, 2005 | 01:26 PM
gglen's Avatar
gglen
misfire
i have a 97 f 150 with a 4.6 number 4 cyl is misfiring any suggestions? the truck was tuned less than a year ago.
Old Jun 29, 2005 | 01:37 PM
lancekilgore's Avatar
lancekilgore
That year has plug wires right?? If so it could be either the plug is bad or the wire. If it is the plug change them all. If it is the wire then I would say again buy a new set and change them all. Most plug wires last about 100,000 miles. once one goes the others follow. watch your washing of the engine water can get down there and cause problems.
Lance
Old Jun 29, 2005 | 03:27 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome gglen, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 29, 2005 | 03:41 PM
hydrabass's Avatar
hydrabass
I have the same year and engine and have changed the #4 several times due to moisture getting down in there and if you look at the plug you will probably see black lines running down the side of the plug where it breaks down and shorts out in the hole .
Jeff
Went724
Sep 10, 2014 05:53 AM
dimitriaudio
Modular V10 (6.8l)
Apr 9, 2010 08:36 PM
strokin72
Feb 28, 2006 04:41 PM
nallen731
Modular V8 (4.6L, 5.4L)
13
Oct 16, 2005 12:49 PM
