New Rear Shocks
Old 06-29-2005, 05:33 AM
tcparry's Avatar
tcparry
tcparry is offline
Smile New Rear Shocks
Just installed new Bilstein shocks on the rear of my 04. Wow, what a difference, I am really happy.. I could not believe the difference..More solid, smoother ride, almost no bounce from the rear on rough roads..Great...
Old 06-29-2005, 09:34 AM
les017's Avatar
les017
les017 is offline
cool - thanks for more confirmation.
I really want to try the Monroe Reflex but they are WAAAAAAY too expensive.
Gonna just pony for the Bilsteins I guess, I have heard (and bounced) enough
Old 06-29-2005, 01:00 PM
ChrisAdams's Avatar
ChrisAdams
ChrisAdams is offline
I'm still waiting for someone who makes a 'faster' shock but not a firmer shock, for the two wheel drive. With my light Reg cab two wheel drive, The firmer Bilsteins are way too rough ridding for a boulevard cruiser like mine. The adjustable Ranchos sound good, but leaving them set on the minimum sorta doesn't make sense.
The Monroes would be nice, but the best priced place I can order them, says maybe late this summer.
I am still hoping someone else will get into the act.
Chris
Old 06-29-2005, 01:11 PM
les017's Avatar
les017
les017 is offline
I am waiting for a quote from a new online seller. No Answer back yet, but I'll let you all know if I hear anything, good or bad
Old 06-29-2005, 11:44 PM
Ruckus's Avatar
Ruckus
Ruckus is offline
If the Bilstein reduces bounce does it make your truck ride stiffer or hard? Thanks!
Old 06-30-2005, 12:16 AM
ChrisAdams's Avatar
ChrisAdams
Smile
And, any time you post about shocks, how about helping those who are interested by tossing in two or four wheel drive. Whats cool on a 4x4 isn't always what the street drivers want.
Thanks
Chris
Old 06-30-2005, 12:22 AM
Ruckus's Avatar
Ruckus
Ruckus is offline
Hello Chris, I thought the same thing but did not say it. I have heard the FX4 come with a different mounting configuration than others. I wonder what the advantage is and if it is better why did they only did it on the FX4? Any ideas? Thanks!
Old 06-30-2005, 12:26 AM
ChrisAdams's Avatar
ChrisAdams
[QUOTE=Ruckus]Hello Chris, I thought the same thing but did not say it. I have heard the FX4 come with a different mounting configuration than others. I wonder what the advantage is and if it is better why did they only did it on the FX4? Any ideas? Thanks![/QUOTE
I suspect they didn't want the cruisers to ride like the log wag, er 4x4 trucks.
Chris
Old 06-30-2005, 12:31 AM
patriots6800's Avatar
patriots6800
patriots6800 is offline
Whats the diff with the fx4 shocks and the rest of the line shocks they say specially tuned for off road and I know on the older super duties 03 and beyone they were rancho's but whats the diff
Old 06-30-2005, 01:02 AM
Ruckus's Avatar
Ruckus
Ruckus is offline
I have the 4x4 and it rides so smooth I would not even think about changing shocks, unless I was going to lift it or something better came out. I went with Rancho's on my last F250 and it rode like a F350 compared to the stock shock, even on min. I have learned to be careful about buying heavy duty shocks. Good Luck!
Old 06-30-2005, 07:55 AM
WhëëlMå1's Avatar
WhëëlMå1
WhëëlMå1 is offline
I pulled the stock rears out of my FX4, and replaced with some Bilsteins. The overall handling has improved, the ride (while still bumpy)...the harshness of the bumps is gone, and it has made the overall driving experience better.
Old 07-01-2005, 08:05 AM
Hugh D's Avatar
Hugh D
Hugh D is offline
Hi Guys,
Used Monroe Relfex on my last truck, a Chevy which was destroyed in the hurricane last year. I found those shocks not to work as well as I hoped. I only used them on the rear when hauling something kinda heavy, (600 plus pounds), otherwise much too stiff and jouncy. They worked ok with a load. But I did keep them on the front as they stoped the 'pogo' effect on dips. Bilsteins are best for me unless the Edelbrocks will do a better job. I have never used them.
Hugh
Old 07-01-2005, 05:12 PM
Toreador's Avatar
Toreador
Toreador is offline
The stock shocks are sub-par. And this is coming from a highway guy. I've already have one leaking at only 11,000 miles and only a very little slamming/blamming of the truck offroad. Right now I'm leaning towards the Bilsteins slightly over the Edelbrock even though both get rave reviews. I'll have to look into the Monroes to see if they come into the running. One thing for sure is those who use the Bilsteins seem to agree they are perfect balance of comfort yet stiff enough to reduce bounce. Since my 3" Truckxxx lift and new X-Terrain tires the shocks are even more revealed to "bouncing". Good luck to all on their choices.
Old 07-01-2005, 05:14 PM
Toreador's Avatar
Toreador
Toreador is offline
Curious to as why just the rear? My truck gives some bounce to both front and back. Still rates as the best riding truck I've ever driven (and getting better with each mod).
Old 07-01-2005, 05:17 PM
Toreador's Avatar
Toreador
Toreador is offline
???The Reflexes are $39 and the Bilsteins $65? Or is there somthing I'm missing here???
Quick Reply: New Rear Shocks
