not sure what I have
what i do know is that it is 78 F-250 super cab 2wd long box. 400m w/c-6. Has factory air,cruise ,towing mirrors, heavy duty cooling,trans cooler, p/s cooler.3"rear springs w/5 leafs. heavy duty brakes. question is is it a camper special without the badges. truck seems to be set up for serious towing. i hope so .
look in the FAQ forum there is info there or do a search you will find tons of info.
i found this old thread might help you out..
https://www.ford-trucks.com/forums/s...ghlight=towing
All looks good except there isn't an M after 400.
The M follows the 351M no 400.
Also, there hasn't been anything definite regarding what the M means.
All M discussions are like trying to a catch a dust mite.
That's why we don't talk about it anymore
Why is your address in your location ?
I wouldn't put that on here, maybe change it.
That space is for the town/city you live in
ok hear we go, the m is to help diferinciate (sp) between the 3 motors the windsor, clev, and M, (rumors of it being made in the michigan plant) it became known as a Modified and just kinda stuck. it is a clevland block with a 1" taller deck hight and different main bearings. all 335 series motors ( 351m, 351c, 400) have interchangable heads along with a lot of other parts in the motor. yes i know not the place to put this but i want to put some stuff to rest
