Ignition Systems
Old Jun 24, 1999 | 12:38 AM
Todd's Avatar
Todd
Ignition Systems
Anybody out there ever put a MSD or Mallory ignition system on a 300?? And if so, any benifits? Truck is a 92 4x4 with 90,000 mi. and I am just kicking around some ideas for horses and mpg's Also, is there anybody out there that makes a header for the 300?
Thanks
Old Jun 24, 1999 | 07:34 AM
slik's Avatar
slik
Ignition Systems
Say, I believe Clifford and Offenhauser make headers for the 4.9. Maybe Offenhauser only makes the intake. Follow some threads here they talk about split headers with dual exhausts and 4 bbl carbs. I used to have a 4.9 and swapped it for a 351W and slapped an MSD on it. MSD, Mallory, and Jacobs all (I think) use a multiple spark to fire the plugs giving a longer burn time which burns the fuel more efficiently. It's supposed to really help in the higher RPM range when a normal ignition misses firing some of the plugs. These new ignitions reduce those misses in the higher RPM ranges.
Steve
Old Jun 24, 1999 | 08:55 AM
GregCS's Avatar
GregCS
Ignition Systems
Todd,
I have ordered the Clifford headers for my 93' F150 4x4 4.9L and I hopefully will see them in the next week or so. If anyone has opinions on Clifford or another manufacturer please share your thoughts. Here is the info for my order:
Clifford Performance
2330 Pormona-Rincon Rd.
Corona, CA 91720
909-734-3310
909-734-8407 Fax
Jay @ Ext 11
Phillip @ Ext 14
$204 for Headers
$165 for Heat Treatment
$28 for locking bolts
53-0016
Old Jun 24, 1999 | 09:56 AM
GregCS's Avatar
GregCS
Ignition Systems
I am also looking to find out what the best ignition system for the 300 4.9L EFI engine. What experience do you folks have???
Do we want the whole ignition system, or coil, or distributor, etc.
What really will help improve?
Thanks
Old Jun 24, 1999 | 01:02 PM
slik's Avatar
slik
Ignition Systems
The MSD replaces the control module and gives the signal for multiple,rapid fire sparks, but I would change the coil to a high output which would also give you a "hotter" spark (more voltage).
Steve
Old Jun 24, 1999 | 01:51 PM
GregCS's Avatar
GregCS
Ignition Systems
I did some further research and decided on the MSD-6200 6A Ignitions System, and the 8227 MSD Blaster Coil, and Taylor SpiroPro Spark Plug Cables.
The guy at MSD said NOT to get any sort of trick spark plugs or platinum style. He said get the normal Motorcraft or Autolite and to make sure to get 1 level colder and increase the gap by .015 over normal.
I will let you know how it does.
Old Jun 24, 1999 | 02:40 PM
slik's Avatar
slik
Ignition Systems
Nice setup! I've got the same thing except I used the Taylor stainless steel covered wires which the MSD folks didn't like. I also ran a 42" coil wire to my coil mounted on the fender well which is supposed to be a no-no, but it works great and really looks nice and clean in the engine bay.
Steve
Old Jun 25, 1999 | 12:45 PM
91F150's Avatar
91F150
Ignition Systems
Looks like a did a no-no according to the MSD guys, but the only mods I've made to my 300/6 ignition are new Splitfire plugs, splitfire wires and a brass Wells cap and rotor. Seemed to smooth out the idle and give it a little more kick. I get 23mpg on the highway with the gate down and in OD. City driving is less but good.
Can anyone explain more about MSD? What is this?
Thanks,
Guy
Old Jun 25, 1999 | 01:05 PM
slik's Avatar
slik
Ignition Systems
MSD stands for Multiple Spark Discharge. A typical ignition will fire once per compression per cylinder at idle and at higher rpms, it is typical for an ignition not to fire each cylinder, each time around. MSD gives multiple sparks (up to 6) during each compression stroke at idle and, while it doesn't always fire each cylinder during each rotation of the rotor, it does increase the number of cylinders fired each time the rotor makes one complete revolution. This then gives you quicker start ups and increased hp across the entire rpm range.
Steve
Old Jun 29, 1999 | 02:14 PM
91F150's Avatar
91F150
Ignition Systems
What'd the setup cost you? Any results yet?
Old Jun 30, 1999 | 08:11 AM
slik's Avatar
slik
Ignition Systems
S.S. clad Taylor plug wires = $45
42" coil wire = $9
MSD Blaster 2 coil = $35
MSD 6A ignition = $130
If I had to do it over, I would purchase:
MSD 8.5mm plug wires = $59
42" coil wire (Accel) = $9
MSD 8227 coil = $45
Steve
Old Jul 1, 1999 | 05:11 PM
GregCS's Avatar
GregCS
Ignition Systems
None in yet... mechanic still has my truck doing some other things.
Old Jul 2, 1999 | 10:20 AM
Mulletwagon's Avatar
Mulletwagon
Ignition Systems
wdon
Nov 10, 2011 07:41 AM
nobodyspecial
Jul 15, 2011 12:46 PM
Wyatt's1988
1978 - 1996 Big Bronco
Jan 8, 2010 07:44 PM
fordflaresides
Dec 12, 2005 05:35 PM
Rob
Jan 25, 2000 10:05 PM
