Power Window Drive
Old Jun 30, 1999 | 12:50 PM
Mulletwagon's Avatar
Mulletwagon
Power Window Drive
The motor runs but the regulator does not move. Took apart the drive and discovered the three nylon ***** in the pinion assembly were shreaded to dust. No problem, just visit those friendly Ford folks and buy three new nylon ***** ----- not !! They only sell the whole drive assembly (mostly plastic) for a mere $84.00. Gotta be bagin me. Anybody know of an alternate aftermarket source for these @#%// little nylon boogers ????
Old Jun 30, 1999 | 03:59 PM
Phillip Guidry's Avatar
Phillip Guidry
Power Window Drive
There is a brand of auto parts by MotorMite called
HELP! You'll have to get the guy to look in the catalog very carefuuly to see if a kit is available to repair it.If not, there line of rebuilt window motors should offer it, but there again, you gotta look in the book very carefully as they are listed seperately from the motors.If all that fails,some transmissions use nylon ball bearings as check *****, and, you can always get metal ball bearings.
Phillip
Old Jul 1, 1999 | 11:16 AM
deleontow's Avatar
deleontow
Power Window Drive
You could go to most of the wrecking yards, they carrier the repair kit, a new gear and ***** for the window motor, we sell them at our store for about $20.00.
<a href="http://members.aol.com/deleontow/auto/index.htm">http://members.aol.com/deleontow/auto/index.htm</a>
Dave
Old Jul 1, 1999 | 02:40 PM
George Newbury
Guest
Posts: n/a
Power Window Drive
I've found the power window gear replacement kit's at a local junkyard - and at a parts supply house - Yates, for about $25(US).
Old Jul 2, 1999 | 10:20 AM
Mulletwagon
Power Window Drive
Went down to the old Valparaiso, FL Carquest where for the sum of $27.00, they had a gear repair kit in stock. Works great. Thanx for all the comments.
Old Jul 2, 1999 | 09:28 PM
Pastmaster's Avatar
Pastmaster
Power Window Drive
Bushwhacker1
1997 - 2003 F150
Feb 2, 2011 08:06 PM
BuickBrian
Nov 11, 2008 12:03 PM
f100guy
Mar 1, 2005 08:19 PM
russellkr
Nov 1, 2002 04:38 AM
Lloyd Irwin
Bronco II
Mar 9, 2000 10:30 AM
