spindle won't come off
Old Jun 27, 2005 | 06:29 PM
dean307's Avatar
dean307
The u joint on a 78 f 150 4x4 the front left to be exact broke, so I went to repair it. I started to disasemble everything, when I came across the spindle attached to the steering knuckle. the five nuts attached to the lug nuts came off very surprisingly they were very rusted. But the spindle which I thought should just slide off fairly easy won't even move. I think the 27 years of rust bonded the metal like super glue. This has been a big problem for quite some time I have continually sprayed rust buster all over, I have been pounding on it with a rubber mallet, a hammer and chissel, I thought air tools, so I barrowed a compressor and started using a air hammer with chissel. I might have moved it a little but I not sure. Is there any sercrect that I am not aware of I really like to reuse this piece so I am trying to be as gentle as possible, but it is beginning to be very frustrating, Any advice would be great since I am not a professional mechanic, just self taugh in the garage, I would really like to get my truck on the road soon.
thanks, vince
Old Jun 27, 2005 | 06:34 PM
proeliator's Avatar
proeliator
You can go ahead and hit the face of the spindle (where it bolts to the knuckle) with a metal hammer, rather than a rubber one. You won't hurt it any. Otherwise, you can apply some heat to it with a torch; often times a little heat is all you need to break those stubbern bonds.
Old Jun 27, 2005 | 07:24 PM
Fordteamone's Avatar
Fordteamone
dean307
What I have found works best is a big plastic no bounce hammer from Mac or Snap On. You can hit top then bottom and this has always worked for me without damaging the threads. Good luck.
Old Jun 27, 2005 | 09:34 PM
bigf150's Avatar
bigf150
They usually seize on there pretty good if you have air try using an air chisel on it thats what i usally do and it works pretty good
Old Jun 27, 2005 | 11:43 PM
79biggerbronco's Avatar
79biggerbronco
as stated use a dead blow hammer , the bigger the better, hit it strait down till the spindle moves then drive a small chisle in the crack, then hammer up from the bottom, drive another chisle in there, hammer down on the top,chisle, bottom,chisle, til it comes off, remember the chisles are only a fulcrum, your not trying to use them to wedge the spindle off, just as a spacer. When you reassemble it clean the spindle with a wire brush then coat the mating surface, liberally, with grease, this will stop any further problems removing the spindle again.
Old Jun 28, 2005 | 09:57 AM
martin_b's Avatar
martin_b
No No NO. Put the two large nuts back on the spindle, block behind the half shaft with a metal bar through the knuckle and use a large gear puller to remove the spindle. I've done two this week.
Old Jun 28, 2005 | 01:20 PM
bigcrunch2's Avatar
bigcrunch2
when you put it back together, clean the rust of where the spindle goes in the knuckle and use some antiseize
Old Jun 28, 2005 | 05:51 PM
460's Avatar
460
I have a spindle puller I use, it works real well. It is a large internally threaded socket that screws on the spindle and has about a 15 pound slide hammer type thing on it; about 10 seconds and about 3 whacks with the slide hammer it's off. It eliminates the possibility of messing up your spindle also. Maybe a shop near you has one you could borrow/rent?
Old Jun 29, 2005 | 12:08 AM
tjay460's Avatar
tjay460
I had to do what Martin_b did, but I also had to hit it from the back side with a punch to get it moving.
Old Jun 29, 2005 | 12:22 AM
buffalobob's Avatar
buffalobob
pep boys loans the slide hammer and socket (spindle puller)that 460 referenced....it takes a lot more slide hammerin on the old trucks than he indicated though....its how Ford does it...no ruined parts.....good luck
