I have a 1997 Explorer with 124,100 miles on it. About a month ago, my check engline light came on and after having taken it to Autozone, found out the oxygen sensor was running lean and 3 cylinders were misfiring. My father-in-law fixed the problem but the check engine light is still on. Also, my 4WD light started flashing. What would cause the check engine light to remain on and how do I get it to go off? Also, what does the 4WD light flashing mean? How do I fix the problem?
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
MOVED and member notified
