Warm Differential??
Old Jun 25, 2005 | 10:12 AM
924x2150's Avatar
924x2150
Warm Differential??
I pulled a code this week, a 452/PSOM/VSS, no big deal, cause the truck is running good and I haven't had any OD lights, bouncing speedos, or harsh shifting.
I cleared the code and will check the codes in a few days.
I searched FTE and read a few topics about the rear-end speed sensor and speedo PSOM and afterwards decided to go outside and check out the wiring and have a look at the rear. While inspecting the rear I felt that the rear housing was very warm to the touch, I had driven the truck 15 miles and parked it one hour before the inspection. Strange thing is, the brake drums were cold, and the axle was cold.
How much heat is normally generated by the rear gears, should the rear be warm after a 15 mile (no load) drive, and parked for one hour????
BTW, it is a 92 Long bed XLT with 3.08's and stock wheels pushed by an E4OD/4.9L
Old Jun 26, 2005 | 01:28 AM
andym's Avatar
andym
Well, it wouldn't hurt to change the fluid, if you haven't done so recently. I know diffs can get up to 160, so it doesn't sound like it's real far off.
mots42
Feb 5, 2014 07:54 AM
ride_gnu
20
Jan 3, 2012 10:54 PM
BRay09
23
Jul 6, 2011 09:15 PM
superduty4x4
18
Oct 2, 2007 09:01 PM
Playing_Tough
Sep 26, 2006 08:19 AM
