Headliner
Old Jul 9, 1999 | 05:00 PM
slikness's Avatar
slikness
Headliner
I'm losing the headliner on my truck. The cloth is dropping from the ceiling. It's not torn or anything and looks in good shape. It looks like the glue has given out. How do I fix, or do I have to purchase a new headliner, and how difficult is it to replace?
'82 F150 w/351W (orig 300 I6)
Steve
Old Jul 9, 1999 | 06:50 PM
deleontow's Avatar
deleontow
Headliner
You can just reglue you old headliner if it is just coming off. PEP Boys autoparts sell kits or just the spray on glue for them, They are not too difficult to remove. Becarful not to tear or break the cardboard backing.
Dave
Old Aug 2, 1999 | 12:29 PM
Kevin S
Guest
Posts: n/a
Headliner
I bought some plastic pins that are made for this problem from Advance Auto for about $3. They resemble screws but are made of plastic and have large heads. They screw into the cardboard that the headliner is glued to. You don't even have to take the headliner out of the truck and can dye the plastic screws to match your interior (they come in black).
Old Aug 3, 1999 | 07:51 AM
Phillip Guidry's Avatar
Phillip Guidry
Headliner
<center><font size="1" color="#ff0000">LAST EDITED ON Aug-03-99 AT 08:52&nbsp;AM (EST)</font></center>
Hey Steve,if you're gonna remove the board for reglueing,you might as well put a fresh piece of material.You see,the material is a cloth fabric "mated" to a foam backing and what usually happens is the fabric seperates from the foam rather than the foam seperating from the board.Of coarse you can glue the fabric back to the foam with a "foam safe" adhesive but the adhesive may bleed through the fabric showing up as a hard spot. Check an interior or upholstery shop for pricing on them doing the whole job or just the material,you might be suprised.
Phillip
Old Aug 3, 1999 | 12:42 PM
Chris Robinson
Guest
Posts: n/a
Headliner
jse1958
1997 - 2003 F150
Feb 17, 2022 09:18 PM
mixup
Jan 4, 2013 07:57 PM
rvx290
Nov 22, 2008 08:05 AM
2001gocougs
Feb 23, 2007 12:02 PM
Mike W
1966 - 1977 Early Broncos
Feb 9, 2003 12:34 PM
