CCV mod picture.
Old Jun 26, 2005 | 08:07 AM
wayfastwhitey's Avatar
wayfastwhitey
the benefit of the ccv mod is to help get cleaner air intake, for some reason ford has oil vapors circulating through the intake and intercooler and all that stuff probably thinking that the turbo needed lub.??? I am not sure here. But with the ccv still hooked to the intake once you start getting aftermarket parts and your boost starts to rise a lot of times the boots connecting to the intercooler "pop" off because of the oil residue making it slippery. This mod helps cure the boot slip and give you cleaner air into that 7.3L beast.
Old Jun 26, 2005 | 09:19 AM
Kwikkordead's Avatar
Kwikkordead
I plugged the hole with an NPT plug. The tap fit perfectly inside the hole to cut some threads. If you don't have a tap for cutting threads you could simply wrap some aluminum foil several layers deep around the flange on the bottom and secure it with a clamp. Then get some 5 minute epoxy from NAPA and fill the hole. Once the resin has cured remove the foil. Of course you need to thoroughly degrease it first for that procedure.
Old Jun 26, 2005 | 12:12 PM
FLASH 13's Avatar
FLASH 13
do i see a vw fuel filter on the wastegate? whats the deal there?
Old Jun 26, 2005 | 12:24 PM
Kwikkordead
Good eyes. It's to keep the dirt out. I disconnected it and didn't want to cap it in case the boost blew the wastegate open. Didn't want to rupture the diaphram inside. So I put the filter on there to allow pressure to release.
Old Jun 26, 2005 | 12:26 PM
FLASH 13's Avatar
FLASH 13
is that a hose removal mod for more boost?
Old Jun 26, 2005 | 12:28 PM
Kwikkordead
Yes. You'll get better throttle response, too, even with stock fuel programming. The biggest difference comes when you start to mod the truck.
Old Jun 26, 2005 | 12:46 PM
FLASH 13's Avatar
FLASH 13
can you give me a link to the definative post for the hose removal mod and the ccv mod?
Old Jun 26, 2005 | 04:43 PM
wayfastwhitey
I would greatly appreciate a link to those 2 mods also
Old Jun 26, 2005 | 06:16 PM
444dieselrod's Avatar
444dieselrod
It is there for emissions reasons.
Kwik that is alot like what I did on the '96 I was to lazy to take the cover off again and turn it around. main reason for turning it around it so the line can run over the brake booster, and help keep any oil that gets in there in the engine. the '97 is turned around and over the brake booster and it still drips oil out the CCV. http://community.webshots.com/album/344525237nQuMGc
sorry no link to a write up. I dont know where there is one.
Diesel Rod
Old Jun 26, 2005 | 06:24 PM
k2vailkid's Avatar
k2vailkid
Diesel Rod,
Venting the crankcase on the rear bumper, shall we call that the 007 smokescreen mod?? Very crafty indeed Bond.
Old Jun 26, 2005 | 06:52 PM
444dieselrod
Thank you. I honestly don't like it any more, too many people ask questions about it. I am gunna rout it into the exhaust some day. I was bored at work one day, made it up.
Diesel Rod
