O-rings
Old Jun 23, 2005 | 08:25 PM
sean23johnson's Avatar
sean23johnson
O-rings
where can i get a set of injector o-rings? and how much are they?
is there any special tool i need?
Old Jun 23, 2005 | 08:48 PM
Fire Rooster's Avatar
Fire Rooster
blackclouddiesel.com
Old Jun 23, 2005 | 09:58 PM
Stroker_Deezel's Avatar
Stroker_Deezel
you can get them straight from ford too, not to bad, i think about 10-15 bucks per injector, specials tools, i recommend readinga write up on pulling injectors before you do it, its not hard, but you can hyrdolock the motor if you do it wrong.
Old Jun 23, 2005 | 09:59 PM
sean23johnson
where can i find install info?
Old Jun 23, 2005 | 10:08 PM
Stroker_Deezel
http://swamp-donkey.biz/injector_removal.htm
Old Jun 23, 2005 | 10:41 PM
sean23johnson
thanks, i ask this because for about a week now my truck has been blowing white smoke. i just had a noisey injector replaced and i was hoping that is where the smoke was coming from but i was wrong. the truck runs great but it smokes under hard accelaration from a stop, blows puffs of smoke under braking, and even blows smoke while just cruising. the thing that is weird is that it puffs a lot of smoke then it goes away and then it puffs smoke again(with in a few seconds). this truck has me confused. does this sound like bad o-rings to you?
Old Jun 23, 2005 | 10:43 PM
Stroker_Deezel
how many miles are on it?
Old Jun 23, 2005 | 10:48 PM
sean23johnson
only 60,000
Old Jun 24, 2005 | 09:14 PM
idrivehotrods's Avatar
idrivehotrods
Once you get the injector out, immediately stuff a shop rag in the hole. After you instal the new O-rings and get the injector instaled turn the motor over by hand, useing a socket and ratchet on the crank. If you encounter a point that seems as the engine is locked up continue to apply presure untill it free's up. Continueing rotating the engine untill you can make 2 complete revolutions without it hanging up.
coolant runs across the injectors as the engine is runing. When you remove an injector coolant will leak into the cylinder. Thats why you need to stuf a rag in the injector hole as soon as the injector comes out.
By turning the crank over you are forceing the coolant that has gotten into the cylinder, into the exaust. So when you start the motor expect it to smoke some when you first start it up. You may even have to drive it a couple of miles before it stops smokeing
rocketman2440
21
Jan 25, 2011 08:43 PM
ArcticF250
Apr 24, 2010 09:50 AM
BII Plow Truck
Bronco II
Dec 22, 2009 07:32 PM
kent's f-350
Dec 14, 2008 09:51 AM
PETE'S_6.0PSD
Jul 5, 2007 11:12 AM
