1973 F600 VIN help decoding
Old Jun 23, 2005 | 08:07 PM
scarlotti's Avatar
scarlotti
Please help - I'm stuck. I picked up a 1973 F600 crew cab/stake body with a 3000# tommy lift gate for $300. Whats the catch? I doesnt run of course. I do not even know what motor is in the beast. It is not a motor I have seen before in all the 30+ Fords I have owned.
VIN# F60DCR20007
WB 194
Color 6
Model F600 2
Body 8
Trans A
Axle 642
GVW 16000
DSO 250130
Whatever the motor is I also need help with engine swap compatibility. I would much rather drop in a 351 or 390 for ease of finding parts bu tI do not wnat to have to change the clutch housing.
Any help is greatly appreciated
Old Jun 23, 2005 | 09:16 PM
asigalet's Avatar
asigalet
From looking at my Ford shop manual, your truck should have originally had a 330 - 2V H.D. motor with an NP 435 4 spd. The rear end would most likely be a Rockwell f-106 with a 6.80 gear ratio. Hope this helps. I am not sure if the 330 and the 390 are a perfect swap but they may very well be.
Old Jun 23, 2005 | 11:12 PM
LxMan1's Avatar
LxMan1
Welcome to the forum.
Please read this "read first" thread for more info. Check post #6 https://www.ford-trucks.com/forums/s...d.php?t=102632.
Usually, the heavy duty truck engines do not interchange due to larger crank snouts so the accessories and flywheel and such will not fit.
Old Jun 23, 2005 | 11:46 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check with the FE engine forum or the SD engine forum here:
https://www.ford-trucks.com/forums/f...play.php?f=137
Damen69
Nov 19, 2016 10:28 AM
bideawee01
May 12, 2016 02:20 PM
Ed Winegarner
13
Apr 15, 2015 01:37 AM
ByersFarm
May 27, 2014 12:08 PM
ScottnMT
Jun 23, 2011 04:26 PM
