Power door lock, lockdown!
Old Sep 19, 2005 | 11:36 PM
big inch's Avatar
big inch
I have had to replace 1,2,3 and even 4 door lock actuators on SD trucks and Excursions before. I have never known all 4 to go out at the same time, however. That sounds more like a wiring or GEM concern.
Old Sep 20, 2005 | 02:04 AM
Technitom's Avatar
Technitom
Veteran: Navy
usually its a weak or bad ground, it can conduct enough juice to tickle the actuators, but cant handle the volt/amp pull to complete the job... seen this on many fords...
you can try adding a new ground inside each of the affected doors, but that does not always work, especially if the door and chassis ground is not 0-5ohms (short)
Old Sep 20, 2005 | 09:14 PM
tried&true's Avatar
tried&true
I like knowing Im not the only one who's got these door lock problems. Makes me wonder which 'club' I will join next, humm... Thanks for the input on the actuators, I'll try those first.
Old Sep 20, 2005 | 09:48 PM
claydr54's Avatar
claydr54
I'm in the process of getting a ford service manual. I'll let ya'll know what happens when I get it. I still don't think it is actuators.
Old Sep 21, 2005 | 05:40 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 21, 2005 | 07:31 AM
Leader's Avatar
Leader
I solved my lock problems with a can of WD 40. Did have to take door pannel off to get access to everything but WD 40 on everything & work it a bit & all is well again.
Old Sep 21, 2005 | 09:02 AM
claydr54's Avatar
claydr54
Sounds Great! Thanks!
Old Sep 24, 2005 | 11:12 PM
Technitom's Avatar
Technitom
Veteran: Navy
wd 40 also works great for the "door ajar" light sticking on... just shoot a little in each door, works like a champ!
Old Sep 25, 2005 | 09:40 AM
alabamabuddog's Avatar
alabamabuddog
Mine was doing this and I had to replace the locks ( Switch and door locks 99 bucks including tax ) and I found that the arm that ataches to the rod was broken and not working properly.
Old Sep 25, 2005 | 12:00 PM
claydr54's Avatar
claydr54
Mine works half the time.
Old Sep 25, 2005 | 06:22 PM
dirttoo's Avatar
dirttoo
Where do you get the actuators? Ford or aftermarket? price? Thanks!
Old Oct 4, 2005 | 05:20 AM
Sniper101's Avatar
Sniper101
Looks like it has been tracked pretty well, in most of the cases, it has been the actuators. That was the problem in my older Truck as well, I noted the problem when I caught myself playing with the lock switch. I noted that after a few minutes the door locks began to slow down and get "sticky".
But where you noted all 4 going at the same time I would ventue its in the electrical wiring some where, given that is that you already checked the fuse.
But should it not be in the wiring, then I would start with the cheapest part in the chain to replace and go from there.
Best of luck with it!
Sniper101
Old Oct 4, 2005 | 05:32 AM
  #28
alabamabuddog
Mines a 2000 model and they started going out 13 to 14 mos after I bought the thing! What OLDER TRUCKS?
Old Oct 4, 2005 | 07:14 AM
  #29
IB Tim's Avatar
IB Tim
Sniper101
Welcome to FTE
Old Oct 4, 2005 | 07:43 AM
  #30
atomicglock's Avatar
atomicglock
My 2000 F-350 was doing the same thing when I bought it. Pointed it out to the dealer and they fixed it, but I don't remember what exactly it was they did to it. I'm at work right now, so I can't check the repair order, but I'll look when I get home and try to post again.
