cleaner, easier oil changes?
Old Jun 27, 2005 | 11:46 PM
  #31
Putt's Avatar
Putt
nairod- trap doors are one way swinging baffles to keep the oil around the oil pickup. If you don't baffle and trap door the pan when you accelerate, turn and brake, the oil goes where centrifugal force throws it. Baffles direct oil and trap doors-well- trap it where you need it. The fitting is for oil temp sending unit and the kickout is that extra space. The windage trays are still available from Ford Racing last I looked.
Old Jun 27, 2005 | 11:54 PM
  #32
1bigsteve's Avatar
1bigsteve
Talking
I never thought about oil sloshing around in my pan. Next time I drop my pan I'll look into this. Thank's for sharing the info with us, Putt.
-1bigsteve (o:
Old Jun 28, 2005 | 08:59 AM
  #33
bshackelford711's Avatar
bshackelford711
does anyone know a part number for the Fram clean drain system?
Old Jun 28, 2005 | 10:04 AM
  #34
bshackelford711
never mind i got the part number for the sure drain. It is # SD1.
Old Jun 28, 2005 | 10:05 AM
  #35
bshackelford711
Originally Posted by Putt
I upgraded my oil pan by building a larger sump(pic's in gallery) and I run a remote filter also. You could also use hydraulic hoses instead of the fancy Aeroquip, Russel, etc. braided stuff. I use a Summit remote oil filter kit on my '89 4X4 with built hydraulic hoses instead of the supplied hose.
The 428 oil pan started as a move drain and slight increase in capacity project and it now has two trap doors, a kick-out on the drivers side, and 3 baffles inside. I did move the drain like I intended tho! It holds 12 qts.
Those gauges that you have in your dash did you make those your self? I really like those
Old Jun 29, 2005 | 11:51 PM
  #36
Putt's Avatar
Putt
Those are Autometer Classic series 2" gauges. I made the panels they are mounted in.
Old Jul 5, 2005 | 08:01 AM
  #37
71FoMoCo's Avatar
71FoMoCo
I don't know about y'all boys, but my crossmembers usually have a little oil on them anyways, along with everything else under my truck... dang leaks! So a little spillage during an oil change ain't no biggie for me! I just wipe it up and go on.
draboo
Jun 15, 2012 08:03 PM
williamm21
Nov 29, 2009 02:04 PM
Vijay
Jul 31, 2008 06:54 PM
michaelbrainardatwor
33
Oct 14, 2004 09:19 PM
jgates
May 22, 2002 09:33 AM
