BRAKE PROBLEMS
Old Aug 24, 1999 | 11:52 AM
DON HALL
Guest
Posts: n/a
BRAKE PROBLEMS
I HAVE A 92 F250 4X4 HD
ONE OF THE FRONT BRAKES LOCKED UP, AS I HAVE 133000 MILES I REPLACED BRAKES,ROTORS AND CALIPERS. I AM STILL GETTING TOO MUCH DRAG AFTER APPLYING THE BRAKES. YOU CAN FEEL THE TRUCK HAVE TO PUSH, AND IT WILL PULL TO ONE SIDE AFTER BRAKING.
WHAT COULD BE CAUSING THIS?
Old Aug 24, 1999 | 01:53 PM
Phillip Guidry's Avatar
Phillip Guidry
BRAKE PROBLEMS
Allthough not common on FORD,you may want to change the brake hoses just in case they are what is still causing the problem.Another problem may be the powerbooster push rod,but,this would only be if someone removed are changed either the booster or master cylinder since the truck was new.If you check here,make sure the piston of the cylinder can return against the snap ring that stops it,without the pushrod touching it.Post back if you have more info.
Phillip
Old Aug 24, 1999 | 02:39 PM
linder
Guest
Posts: n/a
BRAKE PROBLEMS
I have the same problem with my F150. I've narrowed it down to either a faulty master cylinder or if you can tell which tire is locking, it could be that hose going to that tire.
Old Aug 24, 1999 | 11:38 PM
DON HALL
Guest
Posts: n/a
BRAKE PROBLEMS
THE BOOSTER AND MASTER CYLINDER ARE ORIGINAL.
Old Aug 25, 1999 | 09:24 AM
linder
Guest
Posts: n/a
BRAKE PROBLEMS
Replace the brake line going to the calipers. They can colapse and fluid can get to the calipers but can't return, which causes the brake and calipers to stick.
Old Aug 25, 1999 | 03:45 PM
moe's Avatar
moe
BRAKE PROBLEMS
Old Aug 25, 1999 | 10:07 PM
Dave F
Guest
Posts: n/a
BRAKE PROBLEMS
Make sure the calipers can slide in the rails.
This is frequently overlooked during overhaul.
The rails should be clean and the mating
surfaces on the calipers should be clean as
well. I usually put a little anti-seize
compound in there for good measure.
If the calipers can't slide one side will bind
up against the rotor and drag.
Also, make sure your pads are wearing evenly
every time you have the wheel off. Calipers
can seize just about anytime.
Fordman_95
Feb 18, 2011 07:04 AM
ackeiyword
2009 - 2014 F150
Dec 11, 2010 07:47 PM
ironelk1016
Aug 27, 2010 06:48 PM
f350lord
16
Oct 12, 2009 08:29 AM
MajorFlava
Jul 17, 2001 09:48 AM
